Calipers Will Not Fit Over New Rotors - 1999 WJ - JeepForum.com
post #1 of 19 Old 08-27-2009, 10:09 AM Thread Starter
netmaxweb
I'm trying to fix the warped rotors which have developed in my 1999 GC.
It still has the original Teves calipers which have long since been declared defective (and replaced by the Akebono of course). Anyway, after putting on new PBR rotors, which are about 1mm thicker than my old rotors, I am finding that the calipers will not fit over them. I have depressed the caliper pistons completely using clamps and channel lock pliers but still not enough clearance to fit.
Questions. Is there any way to adjust the clearance between the pads? Or are there different thicknesses of pads? Or is my new PBR rotor designed for use with the newer Akebono calipers only?
Personally I do not want to upgrade my brakes to the Akebonos at this time since the Teves have been working fine. So I'm looking for a solution which would allow the continued use of my Teves with my new PBR rotors.
Best Regards
netmaxweb is offline
post #2 of 19 Old 08-27-2009, 10:19 AM
driabyor
driabyor's Avatar
1994 ZJ
i would check with the parts store to make sure they gave you the right parts
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #3 of 19 Old 08-27-2009, 11:09 AM
Turbonut
You'll find that the rotors are the same for all WJ models, regardless of teh caliper style. Don't have the OE thivkness of the rotor for you to check, but worst case scenario, remove 1mm from the pad material.
Turbonut is offline
post #4 of 19 Old 08-27-2009, 11:13 AM
99avant
Check to be sure you have the right parts. As said above, the rotors are the same.
I have stuck with the teves and have not regretted it.
|94 XJ|4.0|NP231|AW4|8.25 Trac Lock|Lotsa miles - SOLD
|99 WJ|4.7|242HD|Vari-lok|Upcountry+BB|DT8000|Dead as of 10/29/2009
If it aint broke, fix it till it is.
99avant is offline
post #5 of 19 Old 08-27-2009, 11:19 AM
vosevichs
Yes its the same rotor just different calipers.
Some info from wjjeeps
Front brakes
Rotor outside diameter: 305mm
Rotor thickness: 26mm, vented
Rotor weight: 16.5 lbs.
Caliper: Teves FN T48 / Akebono
Lining/Mu: BBA2014TA/0.32
Brake fluid: P/N 04318080AB (DOT 3 / MS-4574)
Jeep Grand Cherokee WJ - Front brake rotors
Scott Vosevich
vosevichs is offline
post #6 of 19 Old 08-27-2009, 11:28 AM
northpaw
1mm should not matter, if you pushed the caliper piston all the way back you should have like 5-10mm free play.
1999 Jeep Grand Cherokee LTD
4,7 Litre V8 Quadratrac II
4 Hella 320, 4 Boch Big Knick, JULA Roof rack, 245/75/16 General Grabber AT2, IRO 4 inch Lift kit
northpaw is offline
post #7 of 19 Old 08-27-2009, 11:38 AM
Turbonut
He's stating that the pistons are pushed in as far as they will go and the pads still won't fit over the rotor.
Turbonut is offline
post #8 of 19 Old 08-27-2009, 11:44 AM
driabyor
driabyor's Avatar
1994 ZJ
if you do take them back .... and are the correct ones... have the parts guy mic them ... compare them to another set.... they may have not been made right....
5.2 liter 242 :)
driabyor is offline
post #9 of 19 Old 08-27-2009, 12:07 PM
northpaw
1mm thicker disc still shouldnt be the problem.
northpaw is offline
post #10 of 19 Old 08-27-2009, 12:10 PM Thread Starter
netmaxweb
Honestly I think the rotors are the right ones. In this case my Teves calipers are so defective that the pistons are not fully uncompressing. I can't even get them to uncompress fully even with tools like channel lock pliers and pry bars.
The pads on these Teves were not fully releasing from the rotors in the first place and that is probably what has caused the warping due to heat and friction.
Does anyone know a way to release any pressure from the brake system so I can uncompress the pistons? I am definitely not getting 5-10 mm of clearance to work with at the present.
post #11 of 19 Old 08-27-2009, 12:13 PM
northpaw
in that case I would get new calipers, I got new ones on my fron axle, since if the pistons already does not go all the way, you will end up destroying a new set of rotors, since the pistons will get worse, until they lock the brake completely as they did on mine
northpaw is offline
post #12 of 19 Old 08-27-2009, 01:12 PM
longboy
2006 WK
Are you compressing the piston while the master cylinder cover is on or off? I always do it with the cover removed, but you gotta keep an eye on the fluid and make sure it's not overflowing the master cylinder.
2006 5.7l WK
longboy is offline
post #13 of 19 Old 08-27-2009, 02:36 PM
rm2001wj
rm2001wj's Avatar
Whenever I have done the brakes on my WJs, I always had to struggle a little to pull the calipers off and put them back on, but I was able to get it done. When you pushed the pistons back, were you able to try putting the caliper on the rotor before releasing the pressure you used to push them back? To me it seemed that the pistons moved forward slightly after releasing the pressure.
rm2001wj is offline
post #14 of 19 Old 08-28-2009, 02:25 PM
Sandbox
Sandbox's Avatar
Whenver I do my brakes I use a big c-clamp to compress the caliper pistons. The WJ is the first vehicle I've ever done with more than one piston in the caliper and I noticed on the first one that when I compressed one piston, the other would push back out. I kept alternating between the two until they were both compressed all the way in. For the other side, I just used the old pad to compress them both at the same time.
2012 JKU Sport S
2004 WJ 4.7 Limited - SOLD
"DULCE ET DECORUM EST PRO PATRIA MORI"
Sandbox is offline
post #15 of 19 Old 08-28-2009, 04:50 PM
Airborne Lee
Airborne Lee's Avatar
This may be a bit overly simple but it does make a difference. Did you pull the cap off the break fluid reservoir??? If not you will NOT be able to compress the pistons to enough to put the caliper back on. (With pads anyway.)
please buy this NEW IN BOX:
3 Previous Jeeps - 01 WJ Ltd, QD & UC - 01 WJ Ltd, QT II - 98 XJ Ltd
Airborne Lee is offline
Replacement of Rotors, Breaks, Calipers: how many people have has issue with those? yukon0013 ZJ Grand Cherokee Forum 15 04-14-2009 02:26 AM
New Akebono calipers - do I need new rotors too? table ZJ Grand Cherokee Forum 2 10-13-2007 07:05 PM
Calipers grinding into Rotors sharky777 ZJ Grand Cherokee Forum 7 10-23-2006 06:39 AM
Feedback in Calipers and Rotors!!! marcoff ZJ Grand Cherokee Forum 1 05-09-2005 06:32 PM
Need your help: Removing Calipers from Rotors on 1999 Grand Cherokee 4x4, front cjdietzman ZJ Grand Cherokee Forum 4 07-01-2004 10:24 AM
