A/C warm at idle over 85 degrees F - JeepForum.com
post #1 of 5 Old 07-01-2009, 09:46 PM Thread Starter
egleas522
2015 WK
Maybe this is just normal for a 99 WJ 4.7L.... when the WJ is idling the A/C eventually gets sorta warm and has trouble keeping up; still cooling and not hot, but not great either. A/C system is perfect; had a tested it holds its vacuum and didn't need any freon, no leaks even.
Could this be a coolant problem? Engine temp never exceeds 210 even over 90 outside.
egleas522 is offline
post #2 of 5 Old 07-01-2009, 10:40 PM
the88thpianoman
2003 WJ
Sounds like a potential airflow problem more than anything. Clean the condenser with a heavy duty degreaser, and clean in between the condenser and radiator, where leaves and bugs and crap build up. Make sure both fans (I believe you have two) are working properly.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #3 of 5 Old 07-19-2009, 10:24 PM
WiCkeDuDe
WiCkeDuDe's Avatar
Im having the same issue with my 02 WJ. Mine has the hydralic cooling fan however. Anyone else have this problem? I am going to assume that even at idle and with the 4.7 the a/c system sound be able to run cool and continuesly?
WiCkeDuDe is offline
post #4 of 5 Old 07-19-2009, 10:28 PM
gbauer
Could also be the AC compressor clutch or a slipping belt.
gbauer is offline
post #5 of 5 Old 07-20-2009, 01:12 AM
elmer_fud
how is the engine tempeture when you idle for a while?
I am thinking it is a lack of airflow to
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
WJ stalls when warm/ doesn't want to idle flexsaharatj ZJ Grand Cherokee Forum 4 11-16-2009 12:18 PM
93 cherokee low idle when warm... cherokee93zj ZJ Grand Cherokee Forum 3 10-22-2008 08:00 AM
Erratic idle until warm lma1973 ZJ Grand Cherokee Forum 7 08-01-2007 02:30 PM
It's a warm 40 degrees here, time to replace tranny t/c seals mrjeep ZJ Grand Cherokee Forum 3 12-24-2005 05:35 AM
Won't idle at around 5 degrees whitebomber ZJ Grand Cherokee Forum 5 01-29-2004 09:50 AM
