A/C Vents don't have the same airflow - JeepForum.com
post #1 of 14 Old 07-10-2009, 12:18 PM Thread Starter
jdharri7
When I turn the A/C on high, it blows a lot of air out of the middle two vents on the dash but the other three vents on the side dont even get half of the airflow that the middle two have. Is there anyway that I can make it a little more even? I just want the vents on the side to blow more air.
02 Grand Cherokee, 4.7L V8, 2" BB, K&N Intake, Shaved Door Handles. Selling stock Tail Lights, Headlights, and Door Handles!
jdharri7 is offline
post #2 of 14 Old 07-10-2009, 05:06 PM Thread Starter
jdharri7
Anyone have this problem?
jdharri7 is offline
post #3 of 14 Old 07-10-2009, 11:06 PM
s0l0ithz
i do but no solution
s0l0ithz is offline
post #4 of 14 Old 07-11-2009, 05:43 AM
Turbonut
Check the fault codes:
http://www.wjjeeps.com/climate.htm
Turbonut is offline
post #5 of 14 Old 07-11-2009, 01:42 PM Thread Starter
jdharri7
There arn't any fualt codes showing up. Everything is working, I just want it to work better! The side vents barely get any air flow.... Thanks though!
jdharri7 is offline
post #6 of 14 Old 07-11-2009, 01:47 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
Like anything in nature, air will take the path of least resistance.
The center vents are closest to the fan.
They will always get the bulk of the flow.
Always been like that, always will be.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #7 of 14 Old 07-11-2009, 01:59 PM Thread Starter
jdharri7
Yeah, that was honestly my fear. I was hoping I wouldnt have to get into the vents and find a way to redirect the airflow. Thank you!
jdharri7 is offline
post #8 of 14 Old 07-11-2009, 02:13 PM
patrick02wj
yea i got this problem too. and my passenger side blows outside temp air, even in the winter.
2002 WJ I6, IRon Rock Offroad 4", JKs adj. trackbaR, Doetsch Tech 8000 Prerunner Shocks, 275/70/17 BFG AT, Black Moabs, tinted tails, Hellas
Alpine IVA-W205 Double din, JL Audio 10w7, Fosgate POWER 600/2, Fosgate POWER 400/4, FOCAL 165V30
patrick02wj is offline
post #9 of 14 Old 07-11-2009, 08:24 PM
rw1978
rw1978 is offline
post #10 of 14 Old 07-11-2009, 10:50 PM Thread Starter
jdharri7
Originally Posted by rw1978 View Post
Well...here goes.
This winter, I cut into the heater box under the passenger dash to inspect the blend doors. Broken, of course. I saved my $100 and just jammed the doors into the 'hot' position. When the weather got warmer, I removed my 'jam' and allowed the doors to fall into the 'cool' position.
If you've done this same procedure, you're aware that there is a part of the heater box that divides driver and passenger side airflow right between the blend doors. I realized that when I removed that piece of plastic, I was allowing the air (the fluid that it is) to follow the path of least resistance - i.e. - the driver side middle vent.
Sooo...I opened up the heater box one more time and re-installed the piece of plastic (I knew I kept it around for a reason!). Now better airflow is all-around!
Tada!!!
So pretty much what you are saying is you installed a plastic piece in the air ducts that changes the flow and makes the air go out of the other vents? Can you still change from hot to cold? And is yours the dual climate type?
jdharri7 is offline
post #11 of 14 Old 07-12-2009, 09:32 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
he put the plastic back that was removed. perhaps yours was removed at some point in the past.
ratmonkey is offline
post #12 of 14 Old 07-12-2009, 01:51 PM
rw1978
What Rat said. I can still control air temp, but not from side-to-side anymore. Yes, it still is the dualzone system, but it does not function that way anymore.
rw1978 is offline
post #13 of 14 Old 07-12-2009, 02:34 PM Thread Starter
jdharri7
Ok! That helps a lot, I will look at that. Thanks so much!
jdharri7 is offline
post #14 of 14 Old 07-12-2009, 08:13 PM
melloyello
If you can funnel down the air(create an orifice) on each side you will create more velocity. It's physics.
melloyello is offline
mist/smoke coming out of A/C Vents and Dash vents scambi ZJ Grand Cherokee Forum 13 06-24-2015 11:45 PM
airflow problem BOBBYBARLOW ZJ Grand Cherokee Forum 1 08-04-2006 09:07 AM
Reduced Airflow! BOBBYBARLOW ZJ Grand Cherokee Forum 2 07-09-2006 08:34 AM
Poor Airflow! BOBBYBARLOW ZJ Grand Cherokee Forum 1 07-08-2006 03:20 PM
Almost No Airflow BOBBYBARLOW ZJ Grand Cherokee Forum 1 06-29-2006 05:27 PM
