A/C Vents Blowing Water? - JeepForum.com
post #1 of 3 Old 08-05-2003, 12:55 PM Thread Starter
cajunc4
Anyone know where the A/C Evaporator drain hose is located on a 98' Grand Cherokee No water dripping when A/C is on? Suspect algea or water deposit clog? Water pouring out of rear floor vent.
Thanx
cajunc4 is offline
post #2 of 3 Old 08-06-2003, 12:36 AM
Millican
Here's the service bulletin from DC for slearing the drain.
http://home.sc.rr.com/janet/TSB/24-06-96.htm
Millican is offline
post #3 of 3 Old 08-06-2003, 11:29 AM
reddog093
Same Problem
I have the same problem in my 96 Grand Cherokee..Didn't figure it out for a while..car smelled like crazy and we finally noticed the back carpet was SOAKED...I'm having my mechanic do it because I also have to get some squeaking/creaking noise fixed (noise is supressed greatly when I apply the brake) and need to have a headlight replaced.
The Crazy Cuban
96 Grand Cherokee Limited
reddog093 is offline
No Heat blowing from vents, but can feel warm air. JPerksR6 ZJ Grand Cherokee Forum 8 02-06-2010 07:02 AM
problems with air blowing only through my defrost vents joshhuwa ZJ Grand Cherokee Forum 1 07-19-2008 08:45 PM
Air not Blowing from vents? 93' Grand Cherokee stylezprodukz ZJ Grand Cherokee Forum 1 11-22-2007 10:50 AM
air cond. only blowing threw ceenter vents 2000 wj ZJ Grand Cherokee Forum 20 07-17-2007 08:37 PM
Defrost not working, blowing out vents instead mattadams ZJ Grand Cherokee Forum 8 11-27-2006 12:52 PM
