A/C vent temp - JeepForum.com
post #1 of 3 Old 07-06-2003, 09:42 AM Thread Starter
Sal
A/C vent temp
How well does a 94 GC Air conditioner cool or are these systems poor at best? I just purchased the jeep and it is 92 degrees outside and at an idle vent temp is 60 degrees. It will cool well on the highway but I live in the city. There is a full charge of 134a in the system. I am curious if the last owner let some air in the system or the compressor is getting weak?
Sal is offline
post #2 of 3 Old 07-06-2003, 03:19 PM
Beachead19
Beachead19's Avatar
My Haynes manual says A/C systems should cool somewhere between 30 and 50 degrees cooler than the ambiant air temp. So In your case I think you are right in there.
Just consider yourself one of the lucky ones...you aren't leaking from the evap, a $1000 fix!
98 ZJ Limited I6
OME SD40
BFG AT
Kolak Ignition
Beachead19 is offline
post #3 of 3 Old 07-06-2003, 06:51 PM Thread Starter
Sal
Trying to improve the temps. Does the newer GC electric fans cool any better. Can they be installed in to an older GC? Or is there an even better aftermarket fan setup?
Sal is offline
CCV vent on CRD?? NetworkMD WK Grand Cherokee & XK Commander Forum 40 12-27-2016 03:00 PM
99 WJ A/C Vent Issues rw1978 ZJ Grand Cherokee Forum 17 07-02-2009 07:33 PM
ZJ vent problems 2steevo ZJ Grand Cherokee Forum 1 10-03-2005 09:37 PM
Question about engine temp/temp guage HighOnH2O ZJ Grand Cherokee Forum 8 07-25-2004 02:36 PM
vent door for AC Scott Highland WJ Grand Cherokee Forum 5 06-12-2004 08:59 PM
