A/C problem on '96 - JeepForum.com
post #1 of 3 Old 05-16-2002, 02:52 PM Thread Starter
MidwestCajun
A/C problem on '96
Went to use a/c for the first time this year and found it wasn't working. The light comes on, but no cold air. Checking under hood, I could see the compressor attempt to spin for a couple of seconds, then click off and continue to repeat this on and on. I am bringing the ZJ to the shop next week, but if anyone can give me a heads up on the problem it would be a great help.
2002 TJ Amber Fire Sport
5spd, Dana44, 3.73, 30" Tires
1996 ZJ Green Laredo 5.2
2" Teraflex BB, ProComp ES3000, Parelli Scorpions
MidwestCajun is offline
post #2 of 3 Old 05-17-2002, 06:14 AM
XJin96style
Its probably the bearing inside the compresser because I had this same problem but mine still works! The bearing is going bad on it so its only a matter of time. Does your Aux fan kick on at all, when you turn on your A/C? If so then your fluid level is ok so that means your compresser is ok. if it doesnt turn on check your fluid level if it is fine then it could be your compresser.
Hope i could help, GOOD LUCK
/\/\/\/\ is here!!!!
2000 XJ Jeep sport stock
"ITS A JEEP THING, DONT TRY TO FOLLOW YOU MIGHT GET STUCK."
XJin96style is offline
post #3 of 3 Old 05-17-2002, 10:46 PM
moabster
moabster's Avatar
2011 WK
Had the same problem with my 93 ZJ. Took it to the dealer, the refrigerant was low. They added some more and put in dye to see if they could find a leak. Worked for a few weeks but started working less efficiently. The dye did not show a leak in the tubing so the dealer figured the leak was in the compressor seal (which was common for that compresor). Results... I traded the jeep in on a 2000...
2000 Jeep Grand Cherokee V8 Stock
93 YJ I6 hard top (really belongs to SPEED)
RE 4.5" Extreme Duty Lift, Advanced Adapters SYE, Tom Woods CV Drive Shaft, EA589 10" rims with 33" x 12.5" MT/Rs
Bullet Proof Front and Rear Bumpers and Tow bar
moabster is offline
is this a battery problem or alternator problem? Lady_Luck ZJ Grand Cherokee Forum 14 01-02-2009 09:04 AM
WJ Heated Seat problem and Mirror Problem JeepPleasure ZJ Grand Cherokee Forum 3 04-10-2008 03:00 AM
Problem with the wheel staus lights on dash and head light switch problem jeep2dmax ZJ Grand Cherokee Forum 0 12-21-2007 08:34 PM
HELP! SOS! 94 GC overdrive problem-Will VSS solve problem tinker1121 ZJ Grand Cherokee Forum 1 07-15-2005 10:08 AM
'93 Starting Problem,,, PCM Problem? jeff_connors ZJ Grand Cherokee Forum 0 01-19-2004 11:53 AM
