A/C Pipes are Hot! - JeepForum.com
post #1 of 4 Old 06-19-2006, 11:48 AM Thread Starter
chris7874
A/C Pipes are Hot!
Ok. The A/C blows cold at first then blows hot; not warm but hot. The length of "cold time" depends on the temperature outside. If it's around 75 degrees it will blow cold for a good 30 minutes. The A/C pipes will be frigid cold and have condensation. If it's 95 degrees out, I get 5-10 minutes of cold at best then it goes hot. At this point the pipes leading from the evaporator to the compressor are HOT as well. The A/C will continue to blow hot until I shut the car off for a few hours. Anybody know whats going on? By the way the system was checked for leaks; no leaks. The pressure on the low side port is right where it should be, 40-45 psi. I've heard this could be a blend door or venting problem. Any thoughts?
chris7874 is offline
post #2 of 4 Old 06-19-2006, 11:49 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
What year GC do you have? Do you have Automatic Zone/Climate Control?
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 4 Old 06-19-2006, 05:25 PM Thread Starter
chris7874
It's a 2003 GC Laredo with manual climate control
post #4 of 4 Old 06-19-2006, 05:31 PM
jeep946
jeep946's Avatar
sounds like you have a plugged orifice tube it is located in the condenser and yo have to replace the condenser to fix it. i would first hook up both the high side and low side gauges and let it run. then when it starts to blow hot let me know what you readings are and i can help you out from there.
94 Grand Cherokee, 4.6 stroker, 7 inch custom long arm kit, 33x12.50x15 Firestone destinations m/ts, flow-master 40 series, magnaflow high flow cat, locked front and rear, super axle kits front and rear, pioneer head unit, CB on channel 10, and a B&M built transmission, switched from a 231 to a 242, 2000 Grand Cherokee steering and knuckles and brakes, no abs, wildwood adjustable proportioning valve, and lots more
jeep946 is offline
Mandrel Bent exhaust pipes CALO93 WK Grand Cherokee & XK Commander Forum 4 05-20-2009 09:26 PM
Factory Pipes ? Psyco6string WK Grand Cherokee & XK Commander Forum 1 03-18-2009 03:07 PM
Gauging Interest: 4.7 Performance Y-pipes? 1337jeeper ZJ Grand Cherokee Forum 3 11-10-2006 05:42 PM
