A/C / Heater problem - JeepForum.com
post #1 of 2 Old 08-02-2013, 04:46 PM Thread Starter
Toughguy80
Hi! I tried to fix the A/C on my 1995 Jeep Grand Cherokee. Once I charged the A/C and the compressor works fine, the air is not cold but not so warm as with the A/C off. It also seems that the air is the same warm in both extreme positions of the temp dashboard selector with the A/C off and it lil bit cooler with the A/C on. The same thing with the inside air intake even though I can hear that the system sucks the air from the cabin - warm in both positions with A/C off, lil cooler with A/C on. I was wondering if something wrong with my HVAC as it seems like the system permanently sucks the air coming from the engine irrespectively to the temp selector position (and the A/C is trying to cool down the air from the engine) or it is still something with the A/C?
Thanks in advance for your comments!
Toughguy80 is offline
post #2 of 2 Old 08-02-2013, 07:33 PM
ZeeJay1997
If you mean that the recirc still draws outside air into the cab, the problem is the recirculating air door.
It also sounds like the blend door is not working.
Check the fuses in the cab. I cant tell you which one it is on the 95
ZeeJay1997 is offline
a/c , heater
