A/C Diagnosis - JeepForum.com
post #1 of 4 Old 05-10-2004, 04:00 PM Thread Starter
900Steve
A/C Diagnosis
it's starting to get hot out and i want to have some A/C this year. for once. i'm a fairly competent DIY mechanic, but i have no experience in the A/C system.
i know mine is shot and have been told that it's empty due to a leak. any ideas in how to trace down the busted component or line?
-steve
94 ZJ, I6
900Steve is offline
post #2 of 4 Old 05-11-2004, 02:23 AM
shadetree
-steve
94 ZJ, I6
hey steve, i own a '94 zj i6 and i've noticed it just don't get cold when the a/c is blasting. i've blown hoses sitting at idle before plus i've had leaks prior to the blow out. i'd reccomend having the dealer take care of it. they use a dye that shows up under black light and its no more magic! they locate the leak and usually its the pressed fittings (hose + metal flange fitting with a open end wrench nut on it). having dealt with hydraulics before these hoses are not something you twist and tweak while the systems under pressure to check. "don't rub your hand down the hose while under pressure either" the high pressure air can penetrate your skin or worse cut through it before you know it (just like hyd fluid). my zj is going in the shop on payday.
? for you.... how many miles do you have on it and have you changed out your cat converter? i've got 130k and i've noticed a loss in power and i've been reading on here that with that kind of mileage the back pressure that can come from a faulty cat is bad for the motor. plus a big loss in fuel economy!! i'm fishing for answers or someone else with common gripes that maybe can lead to a fix. my control arm bushings are bad too and need to be changed. the suspension just don't absorb the drunk bumps or reflective things on the road anymore, this is at 25mph and i have to slow down. i think my dash is going to fall into my lap!
anyone else who has input for steve or i please respond!
-scott
shadetree is offline
post #3 of 4 Old 05-11-2004, 02:42 AM
Buddha_Kip
Buddha_Kip's Avatar
actually, you can buy that dye yourself...it's called a/c system trace dye (catchy, isn't it?). however, you will need the hose hookup to put it in there. bring it to any mechanic that has more than 2 teeth in his head and they can take care of it.
2000 WJ Limited - 2.5" Rusty's springs WAAG 1-piece front brush guard custom built WAAG nerf bars PIAA 580 lighting Custom Paint One-off Aluminum Treadplate Door Entry Guards & Rear Bumper Step
1986.5 Porsche 928S - 18" Moda MD1 Autothority Chips Rear Muffler Bypass Short-Shift Kit
Grease Monkey & HNIC @ Clasik Auto
Buddha_Kip is offline
post #4 of 4 Old 05-11-2004, 07:39 AM
Meerkat
On behalf of all us one-toothed mechanics, you can expect a class action suit in the near future. That is, as soon as I can figure out how to do it...
I know for a fact the toothbrush was invented in West Virginia. If it had been invented anywhere else, it would have been called a teethbrush!
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
Misfire - Diagnosis and possible causes? a_kraker99 WK Grand Cherokee & XK Commander Forum 1 06-24-2009 01:50 PM
A/C diagnosis HELP! LiftedUp ZJ Grand Cherokee Forum 12 08-10-2006 09:44 PM
AC Diagnosis Help? kdavis ZJ Grand Cherokee Forum 13 08-03-2006 06:23 PM
diagnosis please Kyle howard ZJ Grand Cherokee Forum 13 07-23-2006 07:28 PM
Diagnosis help hurk76 ZJ Grand Cherokee Forum 2 02-19-2005 10:00 PM
