A/C Condensor - JeepForum.com
post #1 of 9 Old 06-11-2008, 08:54 AM Thread Starter
-cAcHe-
-cAcHe-'s Avatar
A/C Condensor
Will the A/C Condensor have any part in the cooling of the JEEP?
i took off my front aluminum plate from my bumper because the Temp would go up while driving on the higway,after i took it off it was fine,wouldnt get past 210....but now when i turn my A/C on the temp goes up to the next line after 210??? any ideas???
Originally Posted by CarolinaWK View Post
I like happy endings :2thumbsup:
RIP Troy Edwards (bigbluezj94)
-cAcHe- is offline
post #2 of 9 Old 06-11-2008, 10:02 AM
zaq123
zaq123's Avatar
1941 JK Wrangler
Originally Posted by cAcHe96 View Post
Will the A/C Condenser have any part in the cooling of the JEEP?
I'm not sure if I completely understand the question here but yes, working A/C system contributes to the engine temperature, more load+hot ac condenser = heat.
Good things to start replacing under the regular maintenance: radiator cap, thermostat, fan clutch, radiator. 96 with the original radiator is no good, way overdue
zaq123 is offline
post #3 of 9 Old 06-11-2008, 11:42 AM
FPKites
ZJjazzyJim
FPKites's Avatar
It's also a good idea to clean out the radiator and condenser from the back. A combination of air and water do a good job. If there's gunk between the fins, you're losing airflow.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #4 of 9 Old 06-12-2008, 09:36 AM Thread Starter
-cAcHe-
-cAcHe-'s Avatar
Yea well i have already replaced the t-stat radiator water pump and everything due to cooling,ysterday i took apart my front end and cleaned out my condensor,there was bees,flies,leaves everything in there...and alot of oil mixed with dirt,so hopefully this will help with my cooling.
-cAcHe- is offline
post #5 of 9 Old 06-12-2008, 09:38 AM
FPKites
ZJjazzyJim
FPKites's Avatar
I suspect you're on to something there
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #6 of 9 Old 06-12-2008, 09:49 AM Thread Starter
-cAcHe-
-cAcHe-'s Avatar
hahah yea i know..i'll find out later today..my dad took my jeep and dropped it off at the shop..finnaly putting on my 4.5 lift on..and see how it does on the way home with the clean condensor.
-cAcHe- is offline
post #7 of 9 Old 06-12-2008, 09:51 AM
FPKites
ZJjazzyJim
FPKites's Avatar
I'm fairly confident you'll see vastly improved cooling with your newly found airflow.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #8 of 9 Old 06-12-2008, 10:04 AM
kongpheng
x2!! I agree with FPKites. Power wash condensor fan and clean the junk stuck between the fins.
2001 Cherokee XJ Sport 4.0L
3" Rough Country Lift w/ Daystar 1.25" TC Drop Kit
Flowmaster Delta 40 Series
K&N Drop in Air Filter & Procomp 10" E-Fan
AirRaid TB spacer w/ 62mm Bored TB
BFG All-Terrain K.O. on Black ProComp 87's
kongpheng is offline
post #9 of 9 Old 06-12-2008, 10:36 AM Thread Starter
-cAcHe-
-cAcHe-'s Avatar
yea thats what i did haha took it to the car wash and sprayed the **** out of it....first with soap..then just the rinse...you could see the difference right away..
-cAcHe- is offline
E-Fan in front of condensor??? -cAcHe- ZJ Grand Cherokee Forum 22 12-17-2012 04:51 PM
after condensor repair, belt coated with something luckyjeep ZJ Grand Cherokee Forum 6 10-21-2009 06:23 AM
Took Condensor off and..... -cAcHe- ZJ Grand Cherokee Forum 3 08-07-2008 11:50 AM
A/C Problems - Leak at Evaporator Core & Condensor rflem550 ZJ Grand Cherokee Forum 10 06-24-2008 12:14 PM
Ac Condensor Leak On Carpet oldtex ZJ Grand Cherokee Forum 2 07-05-2006 04:27 PM
