A/C Compressor Cycling - JeepForum.com
post #1 of 9 Old 05-22-2007, 10:33 AM Thread Starter
agarb
1994 ZJ
Recharged the A/C on my '94. The gauge on my recharging hose is running in the green with the compressor off and goes up to the yellow when compressor kicks on.
With vehicle idling in park, and the A/C and blower fan on high, the compressor cycles off and on... about 2 seconds on then 5 seconds off and repeating. Air doesn't get cold. My Haynes manaul is pretty worthless when it comes to diagnosing A/C problems. Any suggestions?
agarb is offline
post #2 of 9 Old 05-22-2007, 11:02 AM
Yardman Harry
O
Yardman Harry's Avatar
It is my understanding that the AC will cycle on and off as described in order to keep the air coming out of the windsheild defrosters dry. This helps in defrosting your windows. So to answer your question, yes this is normal operation of your AC.
HTH
Harry
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #3 of 9 Old 05-22-2007, 11:59 AM
SnaFu2
My '97 GC was doing the same thing, cycling on and off. it was low on freon, got it charged up and the cycling stopped and had ice cold air.
SnaFu2 is offline
post #4 of 9 Old 05-22-2007, 02:29 PM
aeroshadow
The refrigerant charge is insufficient that's why the compressor cycles on and off.
I bought a refrigeration manual, (Haynes)a set of refrigeration gauges with pressure scales from Harbour freight, and the small cans of R134 from AutoZone.
Following the specs in the ZJ service manual and air conditioning now works as it should. ( of course I had to replace the evaporator prior to recharging the air con. ( that's why the R134 had leaked out) and that was a job I hope never to have to do again!) The dealer quoted me $1500 for this job so I did it myself. Aeroshadow
aeroshadow is offline
post #5 of 9 Old 05-22-2007, 02:44 PM
rossb
I have to double check my shop manual but I think the 94 Jeep is CCOT? CCOT (Clutch Cycling Orifice Tube) is designed to cycle to prevent evaporator freezing, but that sounds like too much cycling.
CCOT Cycle time is based on high and low side pressures and it is highly dependant on fan speed and ambient temps. What kind of pressures are you seeing on both the low and high side when it cycles? Describe what the needles are doing on both the high and low sides. Are you building adequate pressure on the high side? Just about every type of AC system will cycle if the low-side pressure drops below a specific point. The low-side pressure drop can be caused by low temps near the evaporator or a low refrigerant charge.
rossb is offline
post #6 of 9 Old 05-23-2007, 08:44 PM
alivenkickin28
mine does this every once in while -- i have new evap, new drier and new compressor -- i didnt have it vaccumed out since all the parts were new - i was thinking that maybe i had a little air in the system -- but i have cold air though -
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
alivenkickin28 is offline
post #7 of 9 Old 05-23-2007, 08:53 PM
SpeedyCat3
Survivor
SpeedyCat3's Avatar
I usually pull a vaccum and have it hold for at least half an hour just to make sure there are no leaks.. If it leaks it will not hold.
Then I use the same vaccum pulled to suck in the new oil and get started with recharging. Easiest way to make sure there is no air in the system.
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
SpeedyCat3 is offline
post #8 of 9 Old 05-23-2007, 10:23 PM
rossb
That is not the proper way to service an AC system. Anytime the system is opened to the ambient air it should be evacuated (pull vacuum).
rossb is offline
post #9 of 9 Old 05-28-2007, 06:34 PM Thread Starter
agarb
1994 ZJ
Despite gauge showing in the 'warning' range, I ended up adding a little more freon. Compressor is running pretty much continuously now. Metal line on the low side is getting cold and air coming from vents in vehicle seems to be colder. Hopefully this takes care of everything, but must wait for hotter weather to fully test it.
agarb is offline
AC Compressor Cycling steelstr45 ZJ Grand Cherokee Forum 5 12-17-2009 03:34 PM
RE mono tube. Did it go bad? Will it get better after cycling in and out? bjl95mustang ZJ Grand Cherokee Forum 6 10-09-2009 06:09 PM
AC system cycling problem former520 ZJ Grand Cherokee Forum 6 04-14-2009 07:38 AM
A/C clutch cycling constantly arsonist_bob ZJ Grand Cherokee Forum 4 11-28-2008 02:59 PM
93 grand cherokee a/c compressor short cycling? ed93grand ZJ Grand Cherokee Forum 2 07-03-2005 10:52 AM
