A/C Compressor clutch - JeepForum.com
post #1 of 3 Old 03-23-2013, 03:27 PM Thread Starter
KurtLynch
I've got at 5.9 ZJ and the Compressor clutch bearing was goin out so I bought a Compressor clutch rebuild kit from eBay. It didn't come with and Instructions showing how to install it. I'm sure I could just put it back together the way I take it apart. But I'm the kinda guy that likes to be on the safe side and have Instructions. So does anyone know where I could find Instructions on rebuilding compressor clutch?
Thanks
Kurt
KurtLynch is offline
post #2 of 3 Old 03-23-2013, 05:22 PM
classicmetalman
Not trying to be a smart-***, but might wanna try searching either on JF or the internet. I've bought AC parts from ACKits.com and they have a forum for things like this. Give it a shot, good luck.
Robert
93 Laredo 4.0
96 Limited 4.0
Originally Posted by murphydajeep View Post
I say you should still hit something just to let it know you mean business, or shake a hammer at it in a menacing fashion
classicmetalman is offline
post #3 of 3 Old 03-23-2013, 06:05 PM
KJK
Here's some instructions:
1) Remove 10mm bolt in center of face plate.
2) Pull off face plate.
3) Remove snap ring and pull off pulley/bearing assy.
4) Another snap ring holds the magnet on.
5) The bearing is staked intp the pulley and must be pressed out.
6) The new bearing needs to be pressed in and re-staked with a hammer and a punch. It's most important to support the center of the pulley during these pressing operations because it can be easily distorted if it's supported by the outer edge only.
7) Re-assembly is opposite of removal.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
