Buying a 94 GC tomorrow. ..some questions - JeepForum.com
post #1 of 3 Old 12-10-2011, 02:55 AM Thread Starter
Carroll182
1994 ZJ
Hey thanks for taking the time to stop in...
Before i start, i currently own a 93 GC with the 5.2. The engine is knocking and squeeling TERRIBLY bad. Waiting for warm weather to tear it down and see if its worth fixing.
So now, i decided to get a 4.0. like the title says its a 94 with 179,000 on it. I just want to get a few things figured out so when i get it home I can start on a few things.
Im fairly mechanically inclined by the way, so i will take all the advice you can give...
My first thing is, id like to know what all i need to check/fix/do to it to make sure im not currently having any issues and to prevent future ones. Ive never owned a inline 6 so im pretty new to that. Any sensors i need to check, or gaskets i need to change...etc.
And after test driving it today, i noticed that it has a rough idle while idling in drive (not sure if it does it in park, neutral etc... havent had enough time with it to figure all the small details out.) So i need to know what i could do to fix this.
Yes, i did search a bit, but i didnt find quite what i was looking for.
Thanks for all your help!
Carroll182 is offline
post #2 of 3 Old 12-10-2011, 03:11 AM
Bkuprionas
Rough idle is probably the IAC clean that and while you're there clean the throttle body.
Bkuprionas is offline
post #3 of 3 Old 12-10-2011, 07:13 AM
jtackerman28
Also bad o2 sensor try unpluging it and seeing if it smooths out. Mine did!
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
QUestions before buying 96ZjBurner ZJ Grand Cherokee Forum 2 09-20-2009 03:39 PM
Buying Definity Dakota M/T Tires Tomorrow JackedUPzeejay ZJ Grand Cherokee Forum 25 12-31-2008 11:37 PM
Buying my first Jeep tomorrow.. is this a good deal? udsweetpea WK Grand Cherokee & XK Commander Forum 5 09-01-2007 08:58 PM
May be buying a Limited Commander tomorrow Dan SS2471 WK Grand Cherokee & XK Commander Forum 13 04-18-2007 01:52 PM
Questions about buying used 05 (WK) GC Rivka ZJ Grand Cherokee Forum 10 06-28-2006 02:50 PM
