Burning smell - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Burning smell
XJ guys, clock your transfer case!Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-05-2005, 06:06 AM   #1
zaq123
1941 JK Wrangler
Burning smell
Hi I’m noticing a burning smell (burning rubber or smthg like that) for a week now
And funny thing is that I smell it for a moment right after I just parked it. Nothing smells under the hood, in a tire wells, under the jeep or inside. It drives me crazy. Any ideas?
'97 ZJ
zaq123 is offline   Reply With Quote
Unread 01-05-2005, 08:30 AM   #2
ZJ_COWBOY
1994 ZJ
I have the same problem. Mins a 93zj limited and it smells on ocasion. I think its mud or dirt or grass on my exaust. It happens after i go offroad but it happens on road to. I first thought it was my diffs
RIP 93' ZJ
RIP 98' Dodge Neon
2001 Neon getting 30 MPG w00t!
94 ZJ $200 Project.
ZJ_COWBOY is offline   Reply With Quote
Unread 03-15-2011, 03:55 PM   #3
Adamzero
I know this is an old post, but did either of you find the problem? I recently smell a faint smell for about 30 or 40 seconds after I shut down, thought maybe a diff or oil but I don't see anything
Adamzero is offline   Reply With Quote
Unread 03-15-2011, 04:34 PM   #4
a70eliminator
I once had that smell only to find out my speedo cable was touching the exhuast pipe, i know our jeeps don;t have a speedometer cable but something else like the oxygen sensor wire loom or something may be touching the pipe and slowly melting away causing the smell.
a70eliminator is offline   Reply With Quote
Unread 03-16-2011, 07:23 AM   #5
tomsmoot
I had a similar smell and it turned out my lower radiator hose was leaking and the fluid was blowing back onto the exhaust.
Also, check your CV joints. If you have them there are as many as 3. Two in the axle and one on the front driveshaft.
My front driveshaft CV went up, I smelled burning rubber, but there was the 'angry sparrow' chirping that accompanied the smell. Good luck.
tomsmoot is offline   Reply With Quote
Unread 03-16-2011, 08:34 AM   #6
Adamzero
I think I figured it out. some leafs on my skid plate, and mud. hopefully that was all it was.
