Burning brakes, grinding noise, knocking in rear - JeepForum.com
post #1 of 19 Old 09-17-2013, 07:04 PM Thread Starter
KoltenZJ
Hey all, just a quick question as to what could be going on. I lifted my ZJ Friday/Saturday and had new brakes put in. The front left brake smells like its burning and at one point my pedal got really squishy. Then whenever I turn all the way to the right it sounds like my tire is rubbing on something but I've checked and it seems there can't be anything for it to rub on. That same tire when I make even the slightest left turn it sounds like metal rubbing metal. As far as the rear end goes it sounds like something smacking my wheel well but again nothing i can see that would hit it. It did it before the lift but now it's just intensified. I know I need a new wheel bearing hub and CV Boot on the front left side, but I don't know if any of that is a contributor. Any help is appreciated!
*1997 Jeep Grand Cherokee Limited
3.5" Rough Counrty Lift, 265 75 r16 BF Goodrich All Terrain TA KO Tires
Check out my build thread!
KoltenZJ is offline
post #2 of 19 Old 09-17-2013, 07:17 PM
txbass06
When you say "new brakes" what exactly do you mean? Just new pads or more? Caliper could be sticking on the front causing the pads to remain in contact with the rotor. If this is the case, it could be a collapsed brake line or just time for new ones.
As far as the sound you're hearing when you turn left, it sounds like the hub you say is already bad. Jack it up and get that wheel off the ground, grab it at 6 and 12 o'clock and see if there's any play.
Not sure why you'd lift it with it already having these issues though...
txbass06 is offline
post #3 of 19 Old 09-17-2013, 07:19 PM Thread Starter
KoltenZJ
Just pads. Rotors and Calipers were fine. And the knocking was the only thing it was doing before hand.
KoltenZJ is offline
post #4 of 19 Old 09-18-2013, 05:24 AM
Technohead
Pads and rotors work together and should be replaced together. After which you should follow the proper bedding procedure. At the very minimum, rotors should be resurfaced. But since rotors are dirt cheap anyway its foolish to resurface.
Sounds like the calipers are not fine. I've lost count of the number of times an old caliper started sticking after replacing pads and rotors. Collapsed brake line is also a possible culprit.
-Eric
Technohead is offline
post #5 of 19 Old 09-18-2013, 10:27 AM Thread Starter
KoltenZJ
That could be the burning but the rubbing is what's getting me the most, I hate noises so much you'd think I'm crazy.
KoltenZJ is offline
post #6 of 19 Old 09-18-2013, 10:34 AM
johns1mj
"Just pads. Rotors and Calipers were fine. And the knocking was the only thing it was doing before hand. "
So the knocking was the reason for changing the brakes?
johns1mj is offline
post #7 of 19 Old 09-18-2013, 10:36 AM
johns1mj
This is on a 1997 grand cherokee with a 5.2-correct? Stupid question but is the axle still attached at the frame? I have seen a couple mounts break/rust off the frame.
johns1mj is offline
post #8 of 19 Old 09-18-2013, 10:46 AM Thread Starter
KoltenZJ
The reason for changing my brakes was the pads were garbage.
KoltenZJ is offline
post #9 of 19 Old 09-18-2013, 10:47 AM Thread Starter
KoltenZJ
Yes it is. I found where it's rubbing when I have the wheel turned all the way to the right. So solved that. However when I have it turned left even ever so slightly it makes the metal on metal sound.
KoltenZJ is offline
post #10 of 19 Old 09-18-2013, 11:03 AM
johns1mj
"I know I need a new wheel bearing hub and CV Boot on the front left side,"
I have found during some repairs I have bent the backing plate for the brakes. This slight bend will allow the rotor/drum to contact the backing plate. If the bend or rust build up is very slight the weight of the turn could cause it to make contact. I am assuming the wheel bearing is loose.
Generic way to test the caliper vs hose problem lift the front end and remove the wheel. Apply the brakes a couple times. Try to spin the left front wheel. How freely does it spin compared to the right front? If there is a large difference release the caliper bleeder. If fluid sprays out the hose is holding pressure. If there is not fluid flow try to compress the caliper. If the caliper compresses hard it is either the caliper pins or piston that is bound up.
johns1mj is offline
post #11 of 19 Old 09-18-2013, 11:26 AM
JeepNicholson
Hey johns, buddy, there's a quote button you can use instead of using actual quotes, it makes it easier for us to tell who is saying what.
JeepNicholson is offline
post #12 of 19 Old 09-18-2013, 11:26 AM
Technohead
There is a knob on the dashboard that's fixes noise. Its called the volume.
-Eric
post #13 of 19 Old 09-18-2013, 11:29 AM
johns1mj
Tried it earlier and received an error message. Guess it was user error.
johns1mj is offline
post #14 of 19 Old 09-18-2013, 11:34 AM
JeepNicholson
Lol who knows? The mobile app isn't the greatest either.
post #15 of 19 Old 09-18-2013, 11:38 AM Thread Starter
KoltenZJ
Awesome I'll give that a shot and see how it goes. Thanks bud!
KoltenZJ is offline
