Bumper build - Page 2 - JeepForum.com
post #16 of 47 Old 09-08-2013, 10:52 PM Thread Starter
jeepster383
Got started on the bumper this past saterday what you see is tacked together so far.
Started on reinforcement on the driver side where I will be mounting the bumper. It's 1/8 reinforced on the side and bottom.
jeepster383 is offline
post #17 of 47 Old 09-14-2013, 07:57 PM Thread Starter
jeepster383
Side piece I cut out with a torch at my uncles. Took it home and shaped them with the grinder.
post #18 of 47 Old 09-14-2013, 08:04 PM Thread Starter
jeepster383
What I did here was cut,heat, bend, and weld to give me more room on my corner pices.
Then started to heat and bend those side pices. I'm doing all this with a grinder except cuting the 3/16 metal. This bumper build requries alot of time and patience. But I did get alot done today.
post #19 of 47 Old 09-14-2013, 09:25 PM
x10radsponge
Looking good so far. I love cardboard and tape...
x10radsponge is offline
post #20 of 47 Old 11-09-2013, 07:03 PM Thread Starter
jeepster383
Got more side pieces on.
Had to do more trimming on that unibody corner. Still more to trim
Also got the passenger side unibody reinforced. Still not welded fully yet
And here's how it sits now.
Not the best pic I should have got more. I did about 8 hours of work on it today. Been busy the past weeks finaly had some free Time today.
post #21 of 47 Old 11-09-2013, 07:34 PM
kg6mov
Hears the voices
kg6mov's Avatar
You can cut the ends of the front x-member off completely, they don't really do much except hold up the stock plastic. Looking good so far!
kg6mov is online now
post #22 of 47 Old 11-09-2013, 07:36 PM Thread Starter
jeepster383
Thanks that was my thought also but I wasent completely sure.
post #23 of 47 Old 11-09-2013, 08:52 PM
Y0ungGunZJ
you may end up needing to trim the ends of your new bumper a little bit when you are at full bump. either at straight on or at full lock.
_______._____. << ----Mine------____.____.
//_|__l__,\____\,___------Dads>> /l __,[____],_
l_--\__\__l---\[]llllll[]| -----------l--|_|-L-OllllllllO-
(o) )-o---(o) )---o-) ) ---------(o) )-o-(o) )--o-) )
Y0ungGunZJ is offline
post #24 of 47 Old 11-09-2013, 08:58 PM Thread Starter
jeepster383
Yeah I wana trim a half inch off at the ends just to be on the safe side.
post #25 of 47 Old 11-09-2013, 09:17 PM
Y0ungGunZJ
it also wouldn't hurt to trim more off the sheet metal that is part of the front crossmember like from the front swaybar bolt back. if that makes sense.
post #26 of 47 Old 11-10-2013, 09:36 AM Thread Starter
jeepster383
Yeah all probly be trimming as much off as a can.
post #27 of 47 Old 11-10-2013, 02:46 PM
kg6mov
Hears the voices
kg6mov's Avatar
Check the last page of my 96 build, I did a lot of trimming on the front end.
post #28 of 47 Old 11-16-2013, 04:14 PM Thread Starter
jeepster383
Okay so today I finished up the other side of the bumper/ unibody. I ended up cuting a section out of each side for Clarence and decided it was still strong enough.
I'm going to leave the front plate off till I fab up the bumper mounts for ease of accsess. I had to stop today since I don't have a torch so ima have a buddy take my traced 3/16 plate and cut out the mounts at his work.
post #29 of 47 Old 11-17-2013, 03:31 AM
spannaflicka
Looking good!!!!
spannaflicka is offline
post #30 of 47 Old 11-17-2013, 07:20 AM
OldManTan
I recognize this zj from instagram.
Lookin good so far!
OldManTan is offline
