Bumper build - JeepForum.com
post #1 of 47 Old 08-20-2013, 09:35 PM Thread Starter
jeepster383
Bumper build
Going to be building a winch bumper for my gfs 93 zj. Thursday I will be picking up a sheet of 3/16 8'x4' metal for 140$. Orderd these lights just now on eBay for $51.
Started by removing the bumper.
Painted the metal for now.
I will start the planning and frame strengthig saterday. All probly start off with carboard templates for the design.
jeepster383 is offline
post #2 of 47 Old 08-21-2013, 03:31 AM
zachjf
Double layer foam posterboard works really good also, its lighter and more rigid than cardboard
Needs parts?
PM
or
zachjf is offline
post #3 of 47 Old 08-21-2013, 08:37 AM Thread Starter
jeepster383
Good suggestion all see what come up with.
post #4 of 47 Old 08-22-2013, 07:19 PM Thread Starter
jeepster383
Got the metal today and the lights. I got blinded hooking them up in daylight. Tonight all do a comparison with the high and low beams.
post #5 of 47 Old 08-22-2013, 07:25 PM Thread Starter
jeepster383
post #6 of 47 Old 08-22-2013, 08:12 PM
riot1987
I have a similar looking square one, Its bright as hell. I use it for a back up light
Build thread^^
riot1987 is offline
post #7 of 47 Old 08-22-2013, 08:28 PM Thread Starter
jeepster383
Yeah if these are bright as I think all get more for her jeep and mine for backup lights
post #8 of 47 Old 08-22-2013, 09:38 PM Thread Starter
jeepster383
Low beam
High beam
Just 1 led light placed near passenger headlight.
post #9 of 47 Old 08-24-2013, 05:34 PM Thread Starter
jeepster383
We'll I decided to start a rough sketch of the bumper out of cardboard and tape. I will be building off the winch plate I had laying around in the garage. I think I got the desighn down how I want it to look.
I bent these pieces of metal and secured with self taping skrews just to hold the winch plate up to desighn around it.
I think I want to make the sides out of 1/8th to save on weight. still should be plenty strong. Next week I should be ready to start building it and during the week reinforce the front end.
post #10 of 47 Old 08-24-2013, 05:53 PM
kg6mov
Hears the voices
kg6mov's Avatar
Looks good, I would tend to drop the winch plate lower into the bumper than that. Looks at riots build, http://www.jeepforum.com/forum/f22/r...grand-1436100/
kg6mov is online now
post #11 of 47 Old 08-24-2013, 06:03 PM Thread Starter
jeepster383
Thanks. Yeah I saw that build I tried to keep mine as high as possible for clearance and out of the way of the grill
post #12 of 47 Old 08-25-2013, 08:21 AM
riot1987
Looking good man. I would use at least 3/16" for your mounts that will go inside the frame rails. 1/8 for the rest should be good. My bumper is pretty heavy and I used both 3/16" and 1/8".
I like having my winch kinda.. "low" if you will. I Tboned a guy going about 50 with my old jeep. It had the same bumper design as my current ZJ. Having that winch kinda buried in my bumper saved it in the accident. Plus it helps keep from blocking my radiator. -Just a thought. Keep it up man, you welding it yourself?
Build thread^^
riot1987 is offline
post #13 of 47 Old 08-25-2013, 10:35 AM Thread Starter
jeepster383
Thanks yeah I will be using 3/16 for the mounts and front of bumper. I'm also thinking of making a bar to go in front of the winch to help protect it. I have a 110 Lincoln all use to tack it all together then find one of my buddy's with a 220 v and all probly weld it.
post #14 of 47 Old 08-25-2013, 10:44 AM
Myusername1674
Like the disign man! Looks sharp! Can't wait to see it done!
Sent from my couch using JeepForum app
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #15 of 47 Old 09-01-2013, 10:39 AM Thread Starter
jeepster383
Cut out some metal to slide in my 1/8 reinforcements. Also cut out some of the bumper pices with a torch. Now to grind all the pieces and hopefully next week put it all together
