build your own control arms - JeepForum.com
post #1 of 16 Old 04-10-2011, 12:34 AM Thread Starter
cp1109
Hi I was wondering if anyone has built there own and if so where did u go to get your heim joints and stuff. I was wanting to build my own to save some money and to get rid of my stock stamped metal arms. I was curious tho in the future I plan on putting a rough country 3 inch spring and shock upgrade to it if I do that should I wait to build them or could i build them but add like a inch or two to help push my axles back into the wheel wells any have any ideas or could help me out thanks.
cp1109 is offline
post #2 of 16 Old 04-10-2011, 11:17 AM
KingtheZJ
some companies that sell good stuff are:
ballistic fabrication
clayton offroad (sells currie products)
currie
polly performance
i would recommend that you make them adjustable. this way when you lift it and start changing things you will be able to dial in the pinion angle and axle placement. i have used the ballistic fab weld on flex joints. they are really nice.
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #3 of 16 Old 04-10-2011, 11:39 AM Thread Starter
cp1109
Ok thanks so much I am just wanting to replace the stock stamp ones. The most ill put on it is 3 inch of lift since its my daily driver but want something that can hold up to light to medium trails. That is what I was wanting to do too is make them adjustable so I can change the angles to fine tune it after I'm all said and done.
cp1109 is offline
post #4 of 16 Old 04-10-2011, 11:43 AM
KingtheZJ
IRO sells rubber bushing sleves so you can use factory rubber bushings on one end which will improve the ride on the road. they also sell control arms pretty cheap. both are in this link
http://www.ironrockoffroad.com/Merch...tegory_Code=UP
'88 XJ
post #5 of 16 Old 04-10-2011, 02:22 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
http://www.ruffstuffspecialties.com/catalog/index.php
that is your one stop shop for what you will need to build control arms, DOM, heims, rubber bushings, they have it.
and at the best prices you will find anywhere.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #6 of 16 Old 04-11-2011, 07:55 AM Thread Starter
cp1109
Wow thanks a lot guys I will do my homework and get back to u on how well it turns out.
cp1109 is offline
post #7 of 16 Old 04-11-2011, 11:49 PM Thread Starter
cp1109
Ok so my homework ended pretty fast when I think I might just buy them. Do u know where a good set of them are at just to replace my stock set up. The other thing I see is why arnt there ever any upper control arms they all look to be for the bottom control arms if u do the bottom u have to do the top too right?
cp1109 is offline
post #8 of 16 Old 04-12-2011, 10:00 AM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
why are you giving up so quickly on building your own arms?
nothing wrong with buying your own arms,
i have a set of arms i am trying to sell, PM me if you are interested.
build thread:
5.9 ANDY is offline
post #9 of 16 Old 04-12-2011, 11:21 AM
1stblack97ZJ
x2 i wanted to see it happen
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #10 of 16 Old 04-12-2011, 11:23 PM
two_much_talk
As the others said, why'd you change your mind?
I've built quite a few arms with the Ruff Stuff heims/bungs. 5/8" heims with 1.5" DOM all the way up to 1.25" heims in 2" DOM. Ruff Stuff carries some of the best quality products you can get. Dan doesn't like to sell junk, period. And great customer service.
Summit Machine sells really good stuff too.
two_much_talk is offline
post #11 of 16 Old 04-13-2011, 07:09 AM Thread Starter
cp1109
I guess I'm not 100% sure on what type of heims to buy to just replace my stock arms example 5/8 or whatever. The other thing is when I'm looking at these well they look to only be for my lower links not the top. I have switched out my dana 30 three times in my gc now to know that the top control arms on the axlle side welll need a fork on that side well do u fab that or can u buy that with the heims? It sounds like you guys have my back so sure ill try it out and see what's going on thanks guys and to 5.9 andy if things hit the fan with the build for sure man. Is ur set top and bottomm for front and rear?
cp1109 is offline
post #12 of 16 Old 04-13-2011, 08:33 AM
1stblack97ZJ
Course we got your back! And If you do build em, make sure you make a write up!
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #13 of 16 Old 04-13-2011, 08:53 AM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
yes, front and rear, uppers and lowers.
also hve a rear track bar and rear track bar bracket.
build thread:
5.9 ANDY is offline
post #14 of 16 Old 04-14-2011, 12:54 AM
madZJ
What brand?
madZJ is offline
post #15 of 16 Old 04-14-2011, 08:40 AM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
Originally Posted by madZJ View Post
What brand?
rubicon express super flex.
build thread:
5.9 ANDY is offline
Adj Control Arms now? Or just wait till I for Long Arms Dodgeram1989 ZJ Grand Cherokee Forum 2 03-22-2011 10:37 AM
Build your own control arms? dvZJ89 ZJ Grand Cherokee Forum 47 12-07-2009 02:00 PM
adjustable control arms on 3.5" short arms (ride quality) 3xX ZJ Grand Cherokee Forum 7 11-29-2009 01:16 PM
control arms brammabull69 ZJ Grand Cherokee Forum 6 03-08-2008 10:49 AM
BDS Control Arms Anyone??? WJJEEPIN ZJ Grand Cherokee Forum 4 09-10-2007 10:00 PM
