Jeep Enthusiast Forums banner
Build?
2K views 13 replies 6 participants last post by  nierace
#1 ·
how do i find out what equipment my 99 GC was built with, where is the build sheet? can i find out using the chassis number? also i heard a romour that all Australian GC came with the upcountry suspension set, my car kinda looks a little higher than some of the stockers on here.. here are some pictures.
Thanks
Chris
See less See more
2
#2 ·
Go to jeep.com and request one you will need last 8 vin digets
If your wj came factory with tow hooks you have UC
#9 ·
there is a link in the GC FAQ i think its blue
#10 ·
According to our records, your vehicle was equipped from the factory
with the following:
*EL - Leather Trimmed Bucket Seats
-AZ - Agate
ABAA - Australia Equipment Group
ABES - Export Equipment Group
ADBP - Protection Group
ADLP - Skid Plate Group
AFFP - Luxury Group
AHCP - Trailer Tow Group
APAS - Monotone Paint
ARPP - Limited Decor Group
AWEP - Up Country Suspension Group
AWSS - Smoker's Group
A29P - 4.7L Engine(EVA)/4Spd A/T 45RFE(DG4)
BAZS - 136 Amp Alternator
BC6S - 625 Amp Maintenance Free Battery
BRYS - Anti-Lock 4-Wheel Disc Brakes
CACS - Low Back Bucket Seats
CBWS - Highline Door Trim Panel
CFNS - Rear 60/40 Folding Seat
CGWS - Next Generation Front Air Bags**
CKDS - Floor Carpet
CKNS - Cargo Compartment Carpet
CKRP - Cargo Net
CKTS - Cargo Tie Down Loops
CLEP - Front & Rear Floor Mats
CLGP - Covered Cargo Storage
CLPS - Door Sill Scuff Pads
CSCP - Cargo Compartment Cover
CSRS - Passenger Assist Handles
CUDP - Mini Overhead Console
CUFS - Full Length Floor Console
DGB - All 4-Speed Automatic Transmissions
DG4S - Multi-Speed Auto 45RFE Transmission
DHAS - Lock-Up Torque Converter
DHFS - Quadra-Trac II On Demand 4WD System
DJJS - Dana 30/186MM Front Axle
DMEP - 3.73 Axle Ratio
DRKS - Dana 44/226MM Rear Axle
EAAC - All Engines
EVA - 4.7L V8 MPI Engine
GBBS - Tinted Windshield Glass
GCBS - Front Door Tinted Glass
GEDS - Tinted Rr Drs/Qtr/Liftgate Glass
GEPS - Flipper Liftgate Glass
GFAS - Rear Window Defroster
GNCP - Sun Visors w/Illum Vanity Mirrors
GNKP - Rear View Auto Dim Mirror
GTFP - Power Mirrors
GXMS - Remote Keyless Entry
GXXP - Sentry Key Theft Deterrent System
HAFP - Air Cond ATC w/Dual Zone Control
HGAS - Hood Insulation
HGDS - Deluxe Insulation Group
JAYS - Instrument Cluster w/Tach
JDFS - 200 KPH Speedometer
JHAS - Var Intermittent Windshield Wipers
JHBS - Rear Window Wiper/Washer
JJAS - Cigar Lighter
JJBS - Dual Note Electric Horns
JJJP - 12V Auxiliary Power Outlet
JKAS - Locking Glove Box
JKPS - 12V Auxiliary Power Outlet
JKYS - Power Accessory Delay
JPBS - Power Locks
JPDS - Power Windows, Driver One-Touch
JTFP - Power 10-Way Heated Memory Seats
KENP - No description found
KRCS - STRIPE/BADGE/MOLDING/COLOR
KSCP - No description found
KTCS - No description found
KUCP - No description found
KWCS - STRIPE/BADGE/MOLDING/COLOR
K4XS - STRIPE/BADGE/MOLDING/COLOR
K5AP - STRIPE/BADGE/MOLDING/COLOR
LACS - Illuminated Entry
LAGS - Warning Chime
LAZP - Vehicle Information Center
LBBS - Courtesy Lamps
LBCS - Glove Box Lamp
LBDS - Ash Tray Lamp
LCBP - Door Courtesy Lamps
LCES - Rear Courtesy/Reading Lamps
LDAS - Underhood Lamp
LDBS - Cargo Compartment Lamp
LETP - Traveler/Mini Trip Computer
LEWP - Radio/Driver Seat/Mirrors Memory
LMRS - RHD Optics Headlamps
LNJP - Fog Lamps
LPSS - CHMSL Lamp
LSAS - Security Alarm
MDAP - Front License Plate Bracket
MFTP - Body Color Grille
MHAS - Black Windshield Moldings
MWGS - Roof Rack
NACS - European II Emissions
NFPS - 20.5 Gallon Fuel Tank
NHBP - Auxiliary Transmission Oil Cooler
NHFP - Power Steering Cooler
NHMS - Speed Control
PX8 - Black Clear Coat
QX8S - Black Clear Coat
RAAC - All Radio Equipped Vehicles
RBAP - AM/FM Cass Radio w/Changer Control
RCES - Infinity Speakers
RDLS - Integrated in Rear Window Antenna
RDPP - 10-Disc Remote CD Changer
SBAS - Power Rack and Pinion Steering
SCLP - Leather Wrapped Steering Wheel
SDUP - Heavy Duty Suspension w/Gas Shocks
SUAS - Tilt Steering Column
TBLS - Inside Mounted Spare Tire
TBWS - Full Size Matching Whl Spare Tire
TTFP - 245/70HR16 OWL All Terrain Tires
TZAS - Goodyear Brand Tires
WDMP - 16X7.0 Lux Alum Gold Wheels
WLZC - All Aluminum Wheels
XEEP - Fuel Tank Skid Plate Shield
XEFP - Transfer Case Skid Plate Shield
XEUP - Front Suspension Skid Plate
XEVP - Tow Eye Brackets
XJHS - Locking Fuel Filler Cap
XPFS - Protective Coating and Remover
YABS - Build To Export Mkt. Specifications
YG6A - 6.2 Additional Gallons of Gas
ZLEP - Spring - Left Front
ZLVP - Spring - Left Rear
ZZFP - Spring - Right Front
ZZVP - Spring - Right Rear
Z6BP - GVW/Payload Rating
Looks like i got some goodies...
Is the extra fuel capacity just a bigger tank??? i cant find a switch for a second on so i guess it is...
Chris
#11 ·
wow...6.2 gallons is a large number...how much gas have you ever put in your jeep? I think avg tanks are about....20.5 gallons?
Top
