Budget Tire Rack Project - JeepForum.com
post #1 of 14 Old 11-27-2005, 05:11 PM Thread Starter
CrawfishStu
Budget Tire Rack Project Now with Photos
So I hate.....hate is too gentle a word.....that my spare tire is in the cab of my truck. Even with the really nice orvis tire cover it just took up too much room. So I decided that I really wanted either a swing gate setup or a roof mounted rack. But.....availability and price limited me. So I saw where this guy online made a rack out of tube steel and I thought what a great excuse to go buy a little welding machine. I know...I won't spend $250 on a rack but I'll go and buy a welding machine. So I was shopping for tube steel and by the time I would have gotten the materials I would have spent a ton on a rack that I didn't really like the looks of anyway. So I left Lowe's a little disappointed and headed over to Target to pick up some stuff.....and one of the things I needed to buy was on this rack that would have been just perfect. I grabbed a manager and haggled with him to check for a rack in the back that was damaged. He found one and I loaded it up. I got it home and used the saws all to cut the brackets off and then used my die grinder to grind down the welds and sand it. I pulled some measurements and drilled some holes. Then I painted the rack with some flat black plasti-dip for a thick durable coating. I mounted the rack under the luggage rack so that I can still use it because I ran the bolts through the top of the tire and put the nut under the new rack so that I can pull the tire off and toss it in the back and go. Because of the curve in the roof and the fact that I wanted to mount it so low profile I went ahead and put a couple of rubber bumpers made out of polyurathane washers under the rack so that they would hit on the plastic rail on the roof before the nuts smash into the roof in case I hit something hard enough to make the rack bounce. So here it is guys. I plan on mounting two lights in the front and two lights in the back as well.
First Time Post with Pictures.......
CrawfishStu is offline
post #2 of 14 Old 11-27-2005, 05:17 PM
walter_da_jpr
4.0 Piston Skirt Victim
walter_da_jpr's Avatar
linky no worky
WALTER
WALTER
walter_da_jpr is offline
post #3 of 14 Old 11-27-2005, 05:26 PM
guango88
Air Trans
guango88's Avatar
unable to see any images
ONE ABOVE ALL
guango88 is offline
post #4 of 14 Old 11-27-2005, 05:31 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Hey newbs,
the links work just fine.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 14 Old 11-27-2005, 05:36 PM Thread Starter
CrawfishStu
Thanks Hunter.
95ZJ, V-8, 231, HP30.LockRight, D44A.Aussie, 8" Rusty's LA, 35x12.5 MTZs, Custom Sliders, Rusty's TC Skid, ARB Front Bumper, Tomken Rear Bumper, Phat Jeeps Steering, + More.
post #6 of 14 Old 11-27-2005, 05:37 PM
walter_da_jpr
Of course they work now. Sweet creation
WALTER
WALTER
post #7 of 14 Old 11-27-2005, 05:45 PM
guango88
Air Trans
guango88's Avatar
great idea but.......will that tubing will hold at hwy speeds! specially been held by 4 screws (full spare could actually weight 30 lbs +), and what is actually holding the spare down? I would try u-clamps,
just a sugestion
still looks good
ONE ABOVE ALL
guango88 is offline
post #8 of 14 Old 11-27-2005, 05:53 PM Thread Starter
CrawfishStu
Guess I could have given more build info. The rack is held to the roof rack by four 3/8x3" bolt with washers and stopnuts. The tire is held to the rack by two 1/2x8" bolts with a few washers to make up the slack and lock washers and standard hex nuts on the bottom. I have had it on for about a week now and you barely hear it move at all and it makes very little wind noise. I was standing on top of the tire and it wasn't bending the tube steel or the rack at all. I'm 150lbs. Haven't seen a milage difference yet either. Over all I spent about 15 bucks on it.
post #9 of 14 Old 11-27-2005, 07:05 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Stu,
can you imagine the wind noise from a 33 MT hanging out up there?
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #10 of 14 Old 11-27-2005, 07:29 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Can you imagine the size of the hernia you'll have when you get it down?
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #11 of 14 Old 11-27-2005, 07:49 PM
Phil Gerard
Former Mod
Phil Gerard's Avatar
Oh heck....I take my 32 up and down everyday a few times for exercise!!
You guys are making me realize that if I do get a flat and I'm alone I'm SOL unless someone stops and helps me get it down!!
Phil
'95 ZJ Ltd. White 4.0L
TW DC DS; ARB Bull Bar, F&R Air Lockers; Superior Axles; Warn Winch; 4.56 gears; ACOS, Addco F&R Sw Bar, JKS Discos, Rr Track Bar & Nerfs, 249>242 Swap, Stillen rotors+Kolak pads, 3 pc. Armor, RE 4.5 Kit + 2.5"BB, Adj. UCAs&LCAs, OME SS, Bilstein 5150s, 15x8 AR Diamond Backs, 33 Truxus MTs, K&N FIPK, RE 62mm TB, Perf. Distr. 4.0L Kit, Exhaust: 2.5" Kolak exhaust FM 70: Optima Yellow, Mean Grn Alt., PIAA 520s, 540s, Kevins Rack, & TB Conversion
Phil Gerard is offline
post #12 of 14 Old 11-27-2005, 07:59 PM
ZJ_COWBOY
ZJ_COWBOY's Avatar
1994 ZJ
Ive herd a lot of people say the same thing, but you have to figure how many times do you really get a flat? Sure if you get one a week, you have bad luck and shouldnt mount a tire up there. But within the two years Ive owned my ZJ Ive only got one flat and it doesnt count because it was a slow leak and not a blow out. I coulda drove home but didnt.
RIP 93' ZJ
RIP 98' Dodge Neon
2001 Neon getting 30 MPG w00t!
94 ZJ $200 Project.
ZJ_COWBOY is offline
post #13 of 14 Old 11-27-2005, 08:23 PM
footinmouth47
footinmouth47's Avatar
i like it but what was the original perpous of the tubing and if i could find two then it would be perfict i have a welder though so it would be much more complicated.
Greg
98 zj (The Vixen) 5.2 V8, 4 in f>r, 31's,
Built not Bought member #247
SOLD:( new DD- 04 polaris sportsman
footinmouth47 is offline
post #14 of 14 Old 11-27-2005, 08:43 PM Thread Starter
CrawfishStu
It was some kind of recycling rack from target that they were using as a temp display. If I put an aggressive tire up there I will put a cover on it......and a small crane to help me get it down.
Wj tire rack???? youngdog17 ZJ Grand Cherokee Forum 19 12-19-2009 11:58 PM
Newb Budget Lifts/Tire Help wjinferno ZJ Grand Cherokee Forum 6 07-21-2009 08:57 PM
My ZJ build thread - AKA "Project Budget ZJ" arveetek ZJ Grand Cherokee Forum 22 03-16-2009 04:26 AM
Tire Rack- Any Suggestions? ZeJokee ZJ Grand Cherokee Forum 7 02-02-2009 11:57 AM
Budget ZJ Home Depot Rack mr_user ZJ Grand Cherokee Forum 9 12-27-2005 04:49 PM
