budget boost q's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > budget boost q's
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiWarn, Smitybilt, Engo, Rugged Ridge Winches at CCORIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-01-2008, 10:32 AM   #1
steve L.
budget boost q's
I was thinkin of the budget boots but have a few questions on em.
1. How good are they compared to an actual lift?
2. will I have to replace my shocks?
3. do they wear over time? or will they last for quite a while
4. what is the biggest lift i can get with a budget boost?
any other info or concerns i should know about them would be nice to know. thanks u guys!
97' ZJ Laredo, I6, NP242
A Little Taste of Jersey Wheelin Of A 1997 & 1998 Jeep Grand Cherokee's For Your Enjoyment.
http://www.youtube.com/watch?v=sxa3-LJhz-Y
steve L. is offline   Reply With Quote Quick reply to this message
Unread 12-01-2008, 10:38 AM   #2
runnerboy2010
give the same height as a liftbut less flex, you will probably need new shocks, from what ive seen they last quite a while
92 YJ
runnerboy2010 is offline   Reply With Quote Quick reply to this message
Unread 12-01-2008, 01:40 PM   #3
Coletrickle
They are just a cheap way to make clearance to fit bigger tires.
They don't allow as much suspension travel as a long coil lift will.
You can get 4.5" BB's from Fat Bob's I think.
They last a long time as long as you use the factory insulators, I think Fat Bob's guarantee's them for life.
You can run stock shocks with up to 2" of BB lift (or so they claim). I'm still running my stock shocks, but everyone tells me they will give out sooner or later. I've had my lift on for 7 or 8 months now I think...but haven't wheeled it really hard.
93 Grand Wagoneer
5.5" Hybrid Lift/BDS CA's
231/skids/33" KM2's
Homegrown Bumper
Aussie
Coletrickle is offline   Reply With Quote Quick reply to this message
Unread 12-01-2008, 01:46 PM   #4
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Coletrickle,
for a ZJ, the biggest BB you want is the 2 inch. Anything over that you run the risk of spitting out a coil spring.
Hunter
00 4.7 Laredo...stock
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote Quick reply to this message
Unread 12-02-2008, 05:57 AM   #5
Coletrickle
Hunter,
I'm not saying it's a good idea, but they are available, aren't they? (larger than 2" BB's I mean).
Just to be the Devil's advocate...don't all ZJ's have coil spring retainers? I thought it was the WJ's without the retainers that like to donate springs to the trail.
93 Grand Wagoneer
231/skids/33" KM2's
Homegrown Bumper
Aussie
Unread 12-02-2008, 11:04 AM   #6
GrandHokie96
ZJ's will do it too, i know someone that at full felx was able to pull his spring out with a 2"BB.
I wouldnt go over a 2" and yes, you can run stock shocks as long as you dont wheel it. If you try to flex too much with stock shocks they will bottom out and you're using them as a bumpstop essentially.
My BB should be going on this weekend (just a broke college student or i would have done an actual lift)
GrandHokie96 is offline   Reply With Quote Quick reply to this message
Unread 12-02-2008, 11:46 AM   #7
steve L.
lol yup just a broke college student here also, or else I would consider a real lift also.
thanks for all the info u guys
