Budget boost Pics for SKorch630 - Page 2 - JeepForum.com
post #16 of 20 Old 08-19-2012, 07:31 PM
SKorch630
I've tried to tap that post (two pictures with the hole) and it isn't enough metal to grab onto. I'm thinking I cut that bump stop down some and just do as I planned. Fill the entire hole with some high strength adhesive, shove the bolt through the bump stop, and into that hole and strap it down so it sets. Once it sets for 24/48 hours its not going anywhere. It's sorta ghetto rigged, but the extended bumpstops were cheaper than the oem ones by A LOT so I went with those knowing I had to attach them somehow. Overall, I think it'll work. I'm going to go without the isolators for now, and see how she rides. Worse case, I pull the spring again and attach them. Not a huge project lol.
SKorch630 is offline
post #17 of 20 Old 05-09-2013, 03:06 PM
tirus89
Holy giant photos Batman!
tirus89 is offline
post #18 of 20 Old 05-09-2013, 05:25 PM
tucsonzj
Holy thread revival Robin!
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #19 of 20 Old 06-27-2014, 05:30 PM
jeepzj1998
Originally Posted by Cherokee95kid View Post
And for the rear I went Isolator BB then Spring. I also used a Tub Drain seal fitting to hold the BB snug to the Spring Retainer.
I also Extended the Spring Posts as well replaced all the Sway Bar Bushings and End Links.
On the rear, Is it possible to use the spring isolator on the bottom of the budget boost? BB-isolator-spring?
jeepzj1998 is offline
post #20 of 20 Old 06-27-2014, 06:17 PM
kg6mov
Hears the voices
kg6mov's Avatar
Depends on the cut of the BB, but generally yes.
kg6mov is offline
Budget Boost Installed w/PICS New Problem Though pajeep09 ZJ Grand Cherokee Forum 30 03-05-2010 04:43 PM
2" budget boost on a budget lambar ZJ Grand Cherokee Forum 17 05-07-2008 10:38 PM
Budget Boost Installed!!! (PICS) utah99'wj ZJ Grand Cherokee Forum 15 05-02-2006 09:55 AM
my ZJ 2inch budget boost pics BradBurdett ZJ Grand Cherokee Forum 17 03-17-2005 11:35 AM
Not another budget boost ? mitchj01 ZJ Grand Cherokee Forum 1 01-05-2005 03:10 PM
