Bucks,Bogs and stalls - cant find the problem - JeepForum.com
post #1 of 5 Old 09-25-2009, 08:23 PM Thread Starter
steelblue94
1994 ZJ
I need some help, and have try everything. I have a problem with it stalling out for no reason then starting right back up and running fine, sparatic bucks and bogs when given gas. The throttle body, IACV, were cleaned, had a tune up no more than a month ago. I am at a loss.
steelblue94 is offline
post #2 of 5 Old 09-25-2009, 08:26 PM
MoonyJohn
MoonyJohn's Avatar
Id seafoam your engine, and gas tank. I did that to mine and my idle is so much better. Not sure if it will fix the starting problem, but i recently fixed my water pump and that fixed my stalling problem i had.
MoonyJohn is offline
post #3 of 5 Old 09-25-2009, 08:40 PM Thread Starter
steelblue94
1994 ZJ
Thanks I'll try the seafoam, But I have already replaced the water pump when I first bought it. I have taken it to my mechanic several time explained and he cant figure out what is wrong.
post #4 of 5 Old 09-25-2009, 09:58 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I know that I have several spark plug wires that were burnt through. I'm also guessing that I need to replace the plugs and the distributor cap or at least remove and check it out for cross sparking.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #5 of 5 Old 09-25-2009, 10:13 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Unhook your o2 sensor and see what happens.
ratmonkey is offline
jeep bucking cant find the problem, help!!! SUfan ZJ Grand Cherokee Forum 9 09-15-2010 10:26 AM
4.0 misfires and evap leak, bogs out and bucks J33pst3r ZJ Grand Cherokee Forum 3 09-09-2008 09:56 PM
WJ in shop 2 times still cant find problem clkj2005 ZJ Grand Cherokee Forum 15 03-09-2008 06:06 PM
Help me find rear driveline vibration problem kingvm ZJ Grand Cherokee Forum 2 02-11-2008 06:30 PM
jeep bucks /bogs under load???!! cherojeep ZJ Grand Cherokee Forum 8 11-22-2007 12:49 PM
