Bucking zj - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Bucking zj
Dan's Old as Dirt Birthday Sale!Premium LED Lighting by VISION X, Proudly sold at ROCKRIDGGEARSHADE Pocket Tops in stock and available at ROCKRIDGE
Unread 07-24-2014, 05:49 PM   #1
Dantheglassman
Bucking zj
93 ZJ full time transfer case. The front diff has been replaced. (before) I bought it.
I installed the front drive line today, and I think the front Diff may have a different gear ratio then the rear. The Jeep pulls left, and right tires squall when I turn. Seems like the rear tires are turning faster then the fronts.
Seem right the right diagnosis?
Dantheglassman is offline   Reply With Quote
Unread 07-24-2014, 06:05 PM   #2
newfieZJ
Definitely check your gear ratios . If no tag , you have to pull the cover , and look for the stamping with the tooth count on the crown gear . Ex : 3:73 would be 41 crown , 11 pinion . 41 divided by 11 equals 3.727 or 3.73 .
Another possible cause is the viscous coupler in the t-case itself . Common failure .
If you pull the front drive shaft again , make sure you use your e-brake to park or it can roll away
newfieZJ is offline   Reply With Quote
Unread 07-25-2014, 01:16 AM   #3
kg6mov
Hears the voices
kg6mov's Avatar
If you were running without a front shaft your VC is gone. Going to need to either replace it or swap to a different t-case.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 31's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, New engine and trans, no front driveshaft, but it's pretty
"Whats wrong with a PT Cruiser?"
"Coulda had a V8!"
96 build thread
Niner build thread
kg6mov is online now   Reply With Quote
Unread 07-26-2014, 07:53 PM   #4
Dantheglassman
Both front and rear have tags. What am I looking for?
Unread 07-26-2014, 07:58 PM   #5
newfieZJ
3:73 on both . Only other option would be 3:55 . It will be on one corner of the tag . You may need to clean it up with sandpaper or something to see the numbers .
Unread 07-26-2014, 07:59 PM   #6
newfieZJ
Kg6mov is right though , if you were running w/o a frt drive shaft , that VC is done also . Only 96+ can get away with that .
