broken steering column / steering wheel loose? - JeepForum.com
post #1 of 3 Old 04-13-2009, 08:35 PM Thread Starter
theksmith
2003 WJ
while wheeling sunday, suddenly there was pop/crack sound from my steering wheel column and then the steering wheel was loose. by loose i mean you can wobble it forward and backward. it is NOT loose when turning left/right, just you can wobble the whole wheel as if it was barely attached to the column.
this is a tilt column, and i can still tilt it and lock the tilt just as always. it's like something is broken between around the key area and the wheel itself.
i removed the airbag and can see the main nut that attaches the wheel to the colum is still firmly seated. i will have to get a puller tomorrow to remove the wheel and further inspect the column inside of where the clockspring and switch stalks go.
in the mean time... anyone had a problem like this before? does the clockspring assembly or some other bearing type assembly in there actually center the column in the housing?
thanks!
theksmith is offline
post #2 of 3 Old 04-13-2009, 09:58 PM
jamoka3
i have the same issue, its been that way for over 2 years now lol, i learned to deal with it, but i would like to fix it one day.... maybe? its on my list, you know the never ending list of things i SHOULD do...
but if you find out whats causing this let me know im def interested.
jamoka3 is offline
post #3 of 3 Old 04-19-2009, 09:49 PM Thread Starter
theksmith
2003 WJ
well i took off the wheel this weekend and found that something inside the column housing was broken (seemed to be inside the tilt area).
ooked like you could maybe take a snap ring off the end of the column and maybe remove the shaft from the housing... but i opted to just grab a new entire steering column from an 04 with low miles at the salvage yard. cost me $150, but that included a new wheel/airbag that i can probably sell on ebay, and clockspring and switches that i will keep for backups since i hear that the clockspring is a common failure.
video showing the play in the column: http://www.youtube.com/watch?v=NEdm1nNdbow
Steering Wheel / Column Squeak - 2000 WJ ddruker ZJ Grand Cherokee Forum 29 02-22-2014 07:12 PM
Steering is clunking at steering wheel extremes eboyer7 ZJ Grand Cherokee Forum 8 07-26-2009 02:17 AM
Steering Column? mcgratryan ZJ Grand Cherokee Forum 1 03-22-2009 01:32 PM
Steering Column? mcgratryan ZJ Grand Cherokee Forum 0 03-20-2009 07:33 AM
steering and steering wheel acting wayyy differently GRDCHRKE555 ZJ Grand Cherokee Forum 10 03-22-2007 07:20 PM
