Broken ignition lock barrel - anyone seen this before - JeepForum.com
post #1 of 2 Old 09-10-2004, 06:16 AM Thread Starter
djorkboy
djorkboy's Avatar
I went to start my 96 GC today and it wouldn't go. The key was turning but it felt like it wasn't connecting with anything until too late. If I pushed it in as hard as I could I could get it started eventually.
So I pulled out the barrel and a section has broken off the bottom where it turns the switch.
The chip in the circle to the right is supposed to be where the other circle is..
Is this common? Is the lock mechanism expensive? Anyone got one lying around that they feel like mailing to a very poor Jeeper in Australia
djorkboy is offline
post #2 of 2 Old 09-10-2004, 09:58 AM
Meerkat
I don't have one, but I would be making a bee-line to the nearest Jeep graveyard to find one. I remember reading that there is a particular procedure for removal and installation on these things, so you may want to do a bit of research before simply plugging in a new one.
Here is some more info:
Ignition Lock Cylinder . OEM part# 4778122
$66.60 USD
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
Ignition Lock Help Needed All2kool ZJ Grand Cherokee Forum 6 09-09-2010 02:29 PM
ignition lock wheel lock disengage ouikikazz ZJ Grand Cherokee Forum 1 08-20-2009 02:56 PM
wj steering lock broken tanboy ZJ Grand Cherokee Forum 0 09-03-2008 05:46 PM
'99 GC Ignition lock broken jeepnick ZJ Grand Cherokee Forum 2 05-07-2008 10:57 AM
'99 broken Key in Ignition wandchegstrom WJ Grand Cherokee Forum 3 01-21-2003 09:03 PM
