broken headlight adjusters - JeepForum.com
post #1 of 26 Old 11-09-2009, 11:43 AM Thread Starter
LordHobbit
Does anybody know if/how I can replace these? Is it part of the grill support? Mine were old and brittle, now they are broken and brittle and the cardboard insert holding the lights up is real attractive.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #2 of 26 Old 11-09-2009, 11:46 AM
Joshhamburger
JY is your best bet. Ive been using clear tape at a spacer to hold them up.
Joshhamburger is offline
post #3 of 26 Old 11-09-2009, 12:23 PM
rugermack
Are they the clips on the back of the headlight ?
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
post #4 of 26 Old 11-09-2009, 01:37 PM Thread Starter
LordHobbit
no, no the hex adjuster screws that are right below the hood. The screws that allow adjustment on the headlights. It broke all apart and now my headlights point down without a little help.
post #5 of 26 Old 11-09-2009, 01:48 PM
rugermack
Kolak can get the parts you need. Pm him and he''l send you a picture of the part and list. I would post it , but damm goverment computers won't let me.
post #6 of 26 Old 11-09-2009, 03:37 PM Thread Starter
LordHobbit
what branch you work for?
post #7 of 26 Old 11-10-2009, 07:15 AM
rugermack
Goverment contractor doing missiles.
post #8 of 26 Old 05-06-2010, 08:36 PM
Sirbreakalot
Hate to bring this thread back up, but I need the plastic pieces that hold the adjusting screws in place. I was replacing my headlight assemblies tonight and broke the inner one on each side.
1998 Grand Cherokee Limited
5 speed/NP231 8.8 swap coming in 2010
Sirbreakalot is offline
post #9 of 26 Old 05-06-2010, 09:52 PM
KJK
Contact Nick.
kolak@aol.com
He can probabaly hook you up.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #10 of 26 Old 05-07-2010, 02:43 PM
rednecktrucker
go to any hardware store and buy some 1/4" threaded rods and make some new mounts. i did it before i sold my zj and never had to worry about them flimsy ball joints any more and to adjust them simply adjust the nuts.
94 GRAND CHEROKEE 4.0 5 SPEED 4X4
2004 CHEVY SILVERADO Z71
rednecktrucker is offline
post #11 of 26 Old 05-07-2010, 05:39 PM
dlvsdh
you will be needing to buy a new header panel and adjusters theres no way to get the gears out without distroying your stock header panel.
95, ZJ, ORVIS, 1 tons, 37's etc.
2002, WJ, overland, daily driver
dlvsdh is offline
post #12 of 26 Old 05-07-2010, 05:41 PM
dlvsdh
for that your going to need new headlights. i looked for weeks and weeks even going to my local dodge jeep place. your talking about the clips on on the lights right
dlvsdh is offline
post #13 of 26 Old 05-08-2010, 09:30 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Sounds about right. I bought the parts and attempted the job twice. Both times I said fork it, it ain't worth the grief. One thing, if they have never been adjusted, they are probably ok. If you spray liberal amounts of PB Blaster down the holes before trying to adjust them, let it soak for a day, and do it on a warm day, you'll be ok.
Here's the lowdown on the ZJ clips
http://www.jeepforum.com/forum/f13/z...g-clip-656869/
HighLonesome is online now
post #14 of 26 Old 05-08-2010, 12:40 PM
rednecktrucker
or all you gotta do is take threaded rods and 4 nuts for each one. one nut on the inside of the rod, then the headlight tab, another nut on that side to tighten the rod to the headlight, then drill a hole in the header panel and put a nut on the rod that will butt against the header panel to keep the rod from going back in the grille, then a nut on the inside of the header panel to secure it.
for adjustment:
to adjust rod inward:
1. loosen nut on engine side of header panel.
2. turn nut on headlight side of header panel towards headlight.
3. retighten nut on header panel to secure.
to adjust rod outward.
2. turn nut on headlight side of header panel towards header panel.
if you do this on all 3 mounts you will not have to replace the header panel or adjustment screws and as a plus your headlights will now be BOLTED to your zj instead of "popped" on. you may spend $20 tops on threaded rods nuts and washers. (6 rods 1/4" dia 8" long, 24 nuts, maybe 24 small washers) and your headlights will be securely mounted. i did this on my zj before i sold it and never had a problem.
YOU WILL HAVE TO DRILL THE HEADER PANEL AND TAKE OFF THE PLASTIC CLIPS ON THE HEADLIGHTS BUT ITS WORTH THE EFFORT AND SAVED MONEY. JOB SHOULD TAKE NO MORE THAN AN HOUR TO DO BOTH LIGHTS.
post #15 of 26 Old 05-08-2010, 05:09 PM
myjeeplovesmud
i ran a 3" dry wall screw in one of mine, and it worked great. all i had to do was use a Phillips head screw driver to adjust them. and it didn't cost me a dime
2004 WJ Limited 4.7 H.O
K&N FIPK - Magnaflow Exhaust
17" XD Series Spy Rims- Custom Painted
ZONE 4" Lift With 32" Duratracs
Hella Lighting - Rola Rack - KOR 3/4 Spacers
IRO Sliders - Rusty's Hooks - Cobra CB
November 2010 GCOTM
myjeeplovesmud is offline
Headlight Adjusters Broken L8ndeb ZJ Grand Cherokee Forum 3 07-13-2009 05:20 PM
Broken Headlight Housing Peacemaker526 ZJ Grand Cherokee Forum 6 03-23-2009 04:38 AM
2008 Grand Cherokee Replacement headlight (broken) where to buy? neuman WK Grand Cherokee & XK Commander Forum 8 10-26-2008 12:00 PM
Headlight Adjusters krazy3 ZJ Grand Cherokee Forum 4 12-19-2006 09:25 AM
Broken Headlight Adjuster naparsei ZJ Grand Cherokee Forum 1 10-28-2004 12:08 PM
