Broken Door Latch...PLEASE HELP... PIC - JeepForum.com
post #1 of 4 Old 12-19-2006, 01:25 PM Thread Starter
adgjqetuo
adgjqetuo's Avatar
So yeah the last few days the interior lights have been flickering on and off inside my truck... I assumed it was the door ajar sensor, but when i took a closer look, I saw this...
This was taken in the Driver's Side door Jam...
The interior lights now stay on constantly while driving, (which maybe is better then flickering) and the alarm doen't "chirp" anymore when all the doors are closed...
Sorry if it's hard to make out, it was taken from my phone in a parking lot.
I'm guesing i might have to take it to a body shop and see if MAYBE there's another way to fix it without having to replace the whole door...has anyone seen anything like this before??
Please help though
04 Jeep grand Cherokee Overland - Sold
98 Jeep Grand Cherokee Laredo SE - Sold
adgjqetuo is offline
post #2 of 4 Old 12-19-2006, 03:45 PM
donkie
I've seen that picture at least twice since I joined the forum about a month or so ago...you can try to shim it with some washers or add a piece of steel on the inside to mount to, but the door is basically shot. Could have been slightly out of alignment, weak steel, rust, poor design or the hinges wore causing ever so slight misalignment. Good news is junkyards are plentiful, you might even find a perfect color match and not have to buy a brand new door which is not cheap
Recovering Jeepaholic
2007 Wrangler Sahara - SOLD
Geaux Tigers!!!
donkie is offline
post #3 of 4 Old 12-19-2006, 04:45 PM
gunthagunth
gunthagunth's Avatar
if you know someone with a welder you can get a piece of sheetmetal from home depot and weld a patch over it. then take the measurments off the other door for bolt hole locations and opening and cut them in with a dremel or something. maybe do it before you weld it on there and position it on there correctly and weld it in place. dont use jb weld like they said to do on JU .
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Clayton arms/Addco's/RE brake lines/35x12.5 bfg muds/Currie steering/K&N/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/Hp30-8.8 4.56/ARB f+r
gunthagunth is offline
post #4 of 4 Old 11-06-2013, 08:57 PM
95GC_Fred
Here is Door Latch Panel Patch Plate to MIG Weld Fix Door
Yes, 7 years later November 2013 , I created a CAD DXF file that you can give to a CNC plasma
cutter machine to create a Door Latch Panel Patch Plate to MIG weld over the existing cracked and
broken thin sheet door metal. Use 16 gauge sheet steel and counter sink the 3 T-30 Torx screw
holes to match the side you are placing the patch on (left or right side). PM with your
questions. This Patch Panel allowed me to keep using my present door. Yes I replaced the door's
lower hinge pin with Doorman Products Part 38422. Looks like 38423 could be the upper hinge pin replacement part
that has a groove and a C-clip for mounting the pin upside down. It says for Dodge RAM pickups, so might be wrong pin size.
Doorman Hinge Pin 38422
Follow these two links for more details.
Fabrication Forum CAD Files and Pictures
and
More Pictures and the DXF and PDF files
File Type: pdf Jeep_GC_Door_Panel_Patch8_dimns_2004c.pdf (31.1 KB, 58 views)
File Type: dxf Jeep_GC_Door_Panel_Patch8_dimns_2004b.dxf (271.9 KB, 61 views)
95GC_Fred is offline
door latch
Grande Cherokee door latch will not latch arory1@shaw.ca ZJ Grand Cherokee Forum 14 02-25-2015 09:36 AM
GC door latch, wont latch arory1@shaw.ca ZJ Grand Cherokee Forum 0 03-02-2009 08:33 AM
WJ door latch fix gpJeep ZJ Grand Cherokee Forum 9 04-11-2007 06:35 PM
rear seat latch broken duckys ZJ Grand Cherokee Forum 7 08-02-2006 05:08 PM
broken rear latch kristine_66 ZJ Grand Cherokee Forum 6 08-23-2004 07:52 AM
