Broke the head off the sway bar mount - now what? - JeepForum.com
post #1 of 9 Old 06-12-2013, 02:22 PM Thread Starter
RoldGold
Besides crying, what else can I do? I can't even dream up a way to get the end of this bolt out of the frame rail, besides magic.
RoldGold is offline
post #2 of 9 Old 06-12-2013, 02:27 PM
MyKeyB
E-z out or drill it out and rethread or helicoil?
Magic is probably the best option.
Rust never sleeps...
MyKeyB is offline
post #3 of 9 Old 06-12-2013, 02:54 PM
xcaliber81
I once broke a lug nut in half trying to get it off the jeep the lugs are inset 2 or 3 inches on my wheels and it was very fun getting it off.
xcaliber81 is online now
post #4 of 9 Old 06-12-2013, 03:22 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
I usually break the EZ out off in the hole. Then I got a real problem.
I'd say use the biggest EZ out you can, spray it down with penetrant a few times over time, and then apply heat when you try to work it back and forth slowly.
Sounds almost like sex.
HighLonesome is offline
post #5 of 9 Old 06-12-2013, 04:37 PM Thread Starter
RoldGold
Classy! Haha, but it was a much needed laugh, since I'm kinda torn between an incredible amount of anger, confusion, and sadness. Once I get that GD bolt out, there will be an obscene amount of screaming. Just like sex.
RoldGold is offline
post #6 of 9 Old 06-12-2013, 09:24 PM
shackwrrr
EZ outs are only for stuff that broke because you overtorqued it, they were never designed to remove rusted fasteners.
My suggestion is to drill completely through the bolt with a pilot drill, then up the sizes until you can either pick the remnants out or you can just re thread it.
shackwrrr is offline
post #7 of 9 Old 06-12-2013, 09:50 PM Thread Starter
RoldGold
Guess I'll drill it out then. Can anyone tell me what the thread pitch is for the sway bar mounting bracket (where the rear sway bar meets the frame rail)? I have the FSM and exploded parts diagrams but it is only labeled as "bolt". How useful.
Thanks in advance!
EDIT: And for that matter, what is the correct size socket/wrench I should use to remove the other bolts? I was using a 5/8" (I believe) which also stripped the head if you can tell in the picture. So that certainly couldn't have helped.
RoldGold is offline
post #8 of 9 Old 06-12-2013, 09:56 PM
shackwrrr
M8x1.25 bolt with 15mm head. Arount 30-35mm long.
post #9 of 9 Old 06-13-2013, 03:56 AM
gearheadnick
Like most newer cars, most of the nuts and bolts are metric. My poor SAE sockets and wrenches are getting dusty
My cylinder head overhaul:
My transmission overhaul: http://www.jeepforum.com/forum/f13/how-change-transmission-electronics-1560948/
gearheadnick is offline
