-   -   Broke the head off the sway bar mount - now what? (http://www.jeepforum.com/forum/f13/broke-head-off-sway-bar-mount-now-what-1535625/)
RoldGold 06-12-2013 03:22 PM
1 Attachment(s)
Besides crying, what else can I do? I can't even dream up a way to get the end of this bolt out of the frame rail, besides magic.
MyKeyB 06-12-2013 03:27 PM
E-z out or drill it out and rethread or helicoil?
Magic is probably the best option. :D
xcaliber81 06-12-2013 03:54 PM
I once broke a lug nut in half trying to get it off the jeep the lugs are inset 2 or 3 inches on my wheels and it was very fun getting it off.
HighLonesome 06-12-2013 04:22 PM
I usually break the EZ out off in the hole. Then I got a real problem.
I'd say use the biggest EZ out you can, spray it down with penetrant a few times over time, and then apply heat when you try to work it back and forth slowly.
Sounds almost like sex. :D
RoldGold 06-12-2013 05:37 PM
Classy! Haha, but it was a much needed laugh, since I'm kinda torn between an incredible amount of anger, confusion, and sadness. Once I get that GD bolt out, there will be an obscene amount of screaming. Just like sex.
shackwrrr 06-12-2013 10:24 PM
EZ outs are only for stuff that broke because you overtorqued it, they were never designed to remove rusted fasteners.
My suggestion is to drill completely through the bolt with a pilot drill, then up the sizes until you can either pick the remnants out or you can just re thread it.
RoldGold 06-12-2013 10:50 PM
Guess I'll drill it out then. Can anyone tell me what the thread pitch is for the sway bar mounting bracket (where the rear sway bar meets the frame rail)? I have the FSM and exploded parts diagrams but it is only labeled as "bolt". How useful.
Thanks in advance!
EDIT: And for that matter, what is the correct size socket/wrench I should use to remove the other bolts? I was using a 5/8" (I believe) which also stripped the head if you can tell in the picture. So that certainly couldn't have helped.
shackwrrr 06-12-2013 10:56 PM
M8x1.25 bolt with 15mm head. Arount 30-35mm long.
gearheadnick 06-13-2013 04:56 AM
Like most newer cars, most of the nuts and bolts are metric. My poor SAE sockets and wrenches are getting dusty :D
The time now is 01:24 AM.
