Brake Rotor Warp? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Brake Rotor Warp?
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 11-05-2008, 07:27 AM   #1
BULLITTBUilder
Brake Rotor Warp?
I would guess that this has been asked before but I want to make sure of what the problem is and what I can do to fix it. From time to time after driving when I get on the brakes the truck shakes. The WJ shimmy only comes from the front wheels and is even from side to side (one side doesn't shake more than the other) This is an intermittent problem and is unpredictable it would seem as to when it happens. In other words sometimes it happens when I first take the truck out, others while driving/returning. I do not ride the brakes nor do I jam on them when I need to stop. If it is rotor warp I don't understand why because all the lug nuts are properly secured. What can I do to fix this problem?
BULLITTBUilder is offline   Reply With Quote
Unread 11-05-2008, 08:17 AM   #2
rm2001wj
Probably not warped, since it is only a "time to time" sort of thing. Unfortunately, I can't say what it is though. My wife's 04 did pretty much the same thing for a while, but after a couple of thousand miles, it went away. Until it went away, I was pretty sure it was warped rotors.
2001 WJ Limited with Quadra-Drive, Kenne Bell Supercharger, 3-inch Kolak exhaust, Stillen rotors (F/R) and MM pads, Addco sway bars (F/R).
rm2001wj is offline   Reply With Quote
Unread 11-05-2008, 08:24 AM   #3
JCZJ
If you wait it out and the warping isn't too bad, the pads may wear the rotors down evenly (or more even than before) anyway.
1998 ZJ // 5.2L // Lifted!
1994 ZJ // 4.0L // 271,000 miles // Some cool stuff // RIP 5/25/08
1965 Ford Mustang 2+2 // Boss 302 Swapped // Locked 9" rear
Originally Posted by Shoey40 View Post
She can XJ my WJ whenever and however she wants. Hell, I'd let her CJ it, too.
JCZJ is offline   Reply With Quote
Unread 11-05-2008, 08:43 AM   #4
ZJPunk98
Addicted to my Jeep
ZJPunk98's Avatar
Well there could be a few issues causing the shaking. I've been through this for the last year. I've replace the entire braking system with an aftermaket one to fix the problem.
First: I disagree with the previous post. If you rotor are worn unevenly, using them longer will not even the wear. I can tell you more about why this is so if you want.
Second: if it is intermittent, it could be a few things such as worn knuckle slider (the part of the knuckle that the pad slides on. this can be different depending on the model), one or two wearing hub and bearing assemblies (in my case 2), your alignment or balancing may be slightly off causing you to notice the skating with certain wheel positions, and finally you should check your steering linkage.
Gotta get back to work... i'll finish the post later
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline   Reply With Quote
Unread 11-05-2008, 09:59 AM   #5
CLNinja
how old are the brakes? ( pads and rotors )
[color="#003300"]Matt[/COLOR]
[color="white"][CENTER][size="1"]
[url="http://www.jeepforum.com/forum/showthread.php?t=434081"][color="white"]Click Here For My Build Thread[/COLOR][/url]
[/COLOR][/SIZE][B]**September 2009 Grand Cherokee Of The Month**[/B]
[SIZE="2"][url="http://www.jeepforum.com/forum/forumdisplay.php?f=123"][color="white"]Colorado Jeep Club Member #88[/COLOR][/url][/SIZE][/CENTER]
CLNinja is offline   Reply With Quote
Unread 11-05-2008, 05:31 PM   #6
BULLITTBUilder
i am unsure how old the rotors are but the pads are less than 1year about 12k miles. it is definitely not steering linkage related because i just changed those parts (drag link,tie rod)track bar is good. its been aligned. the rotors actually look fine no warping/scoring... again this does not occur everyday and the circumstances when it happens are not the same
Unread 11-05-2008, 05:38 PM   #7
99avant
A dragging caliper might do this too.
|94 XJ|4.0|NP231|AW4|8.25 Trac Lock|Lotsa miles - SOLD
|99 WJ|4.7|242HD|Vari-lok|Upcountry+BB|DT8000|Dead as of 10/29/2009
If it aint broke, fix it till it is.
99avant is offline   Reply With Quote
Unread 11-05-2008, 08:45 PM   #8
Redbob
My '04 did exactly as you described, shaking occasionally, but it seemed more related to how hard I was braking - hard braking always seemed to bring it on.
The pads were fairly new, so I just bought new rotors, and that fixed it: my guess is the problem was rotor thickness variation, not at all the same thing as warpage (or runout), and much harder to detect: thickness variation of less than .001" will caused pronounced shaking when braking, even if the runout is well within specs.
Redbob is offline   Reply With Quote
Unread 11-06-2008, 07:22 PM   #9
ZJPunk98
Addicted to my Jeep
ZJPunk98's Avatar
Good point and also as 99avant said it could be a hanging caliper
Erik
Unread 11-07-2008, 12:04 AM   #10
cologc46
cologc46's Avatar
I had braking vibration on my WJ. It is a 2003 and at the time, only had about 20K miles. I feared the vibration would ruin calipers, or wheel bearings, so I replaced the rotors right away. A pair of new front rotors from Napa only cost me about $60 and eliminated the vibration. Easy fix too, just remove the wheel, give the old rotor a whack with a rubber mallet, and put on the new one. Brakes are perfect now. If you dont have money for new rotors, take your old ones to Napa and have them turned, see if that cuts down or eliminates the vibration. Turning cost should be $15/rotor.
cologc46 is offline   Reply With Quote
Unread 02-02-2009, 05:17 PM   #11
ravenldy79
2003 WJ
My '03 WJ keeps eating rotors like it's going outta style. I put new rotors on it last yr that were slotted and drilled and the thing is still warping the rotors. Has anyone had any luck fixing this problem? My boyfriend thought that if we retro fitted '04 brake components on it that this could solve it along with some heavier duty rotors and pads. Any thoughts?
ravenldy79 is offline   Reply With Quote
Unread 02-02-2009, 07:12 PM   #12
Turbonut
'04 would be the same as '03. Make certain the lug nuts are torqued to specification, not by feel or some 800lb gorilla, and stay off heavy brake use. Our '01 had 135K and no rotor problems.
Turbonut is offline   Reply With Quote
Unread 02-02-2009, 07:14 PM   #13
BlackShuck
I've read that unless meticulous care is taken during brake bed-in procedures, that thickness variation can happen over and over again.
Installing '04 parts on an '03 would be pointless.
01 WJ Spec. App. Laredo. Retrofitted with Akebono calipers; Stillen Sport Rotors; Reese Class III Hitch; and a ZJ Front Drive Shaft
Save yourself time, money, and a lot of frustration by NOT shopping at JcWhitney!!
Utah Jeep Crew #8
FS: Rear wind deflectors || || Stock OEM Air Box Set Up
BlackShuck is offline   Reply With Quote
Unread 04-02-2009, 03:24 PM   #14
jeepgcnewbie
My 04 larado has this problem. The lower slide pins on the caliper were rusted in place. Still havent solved the problem but that was part of it and a co-worker thinks that is what ruined my new rotatrs.
jeepgcnewbie is offline   Reply With Quote
Unread 04-02-2009, 04:25 PM   #15
TMCXJ
"If it is rotor warp I don't understand why because all the lug nuts are properly secured."
Could you define what you mean by "properly secured"? If you mean that they've been tightened to proper torque values, then listen to above. If NOT, get your torque wrench out and start there.
"...a long habit of not thinking a thing wrong, gives it a superficial appearance of being right, and raises at first a formidable outcry in defense of custom. But tumult soon subsides. Time makes more converts than reason." Thomas Paine
TMCXJ is offline   Reply With Quote
