Brake Question (looked at FAQ already) - JeepForum.com
post #1 of 4 Old 06-04-2004, 12:28 PM Thread Starter
another_requiem
another_requiem's Avatar
this question didnt seem answered
Will I do fine with old calipers and nice new slotted rotors and good pads
i just ordered brembo's like 20 minutes ago, just wondering if they will warp because of the calipers?
2002 Dodge Ram 1500
5.9 V8
K&N Drop In Filter
mobil 1
Gibson Cat-Back swept side exhaust
Fabtech 6 inch Suspension Lift
ProComp 1869 rims 17x9
ProComp Xterrain tires 35/12.5/17
1994 ZJ
4.0 I6
K&N FIPK generation 2
Dynomax Exhaust
another_requiem is offline
post #2 of 4 Old 06-04-2004, 07:37 PM
acitydweller
its always recommended to get new pads when using new rotors. using old calipers should be fine as it doesnt directly make contact with your rotors.
acitydweller is offline
post #3 of 4 Old 06-04-2004, 09:33 PM
greasefingers
greasefingers's Avatar
1994 ZJ
Thatís an interesting point you bring up. If I understand you correctly: the rotors are notorious for warping. My first Jeep, in 1988, had rotors that warped. So the question is: during the last 16 years, does jeep and aftermarket people supply crap for rotors or is it crappy calipers? I have heard of dual piston calipers, for the jeep-fix. Maybe these distribute the pressure more evenly to prevent localized hot spots? But then why do other single piston calipers seem to work well with other vehicles? Maybe someone can shed some light on why this flaw has been around for so long
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #4 of 4 Old 06-05-2004, 12:22 PM
mrjeep
I had a 1988 Cherokee for almost 10 years that never had a rotor problem. I had my 99 GC at the dealer for recall work and allowed them to turn all 4 rotors and new oem pads. 7,000 miles later I have pulsation in the brakes. I have read other post that oem rotors are a different material to reduce cost. Jeep issued a TSB about the calipers and updated replacements, so they must have concluded that there is the potential for a problem. I'm planning on replacing the rotors with standard rotors (non slotted or drilled) from local autoparts store with new semi-metallic pads. I think it is important to also check that the calipers are functioning properly. I think there is a slide pin that is suppose to be lubricated with caliper grease.
mrjeep is offline
Looked at '98 ZJ TSi Tonite stageninja ZJ Grand Cherokee Forum 11 10-09-2008 09:28 PM
just looked at a 2001 WJ need advice fivespeedsteed ZJ Grand Cherokee Forum 10 11-24-2007 11:59 PM
Just looked at a 5.9...please help Steve98 ZJ Grand Cherokee Forum 5 09-03-2006 11:36 PM
Looked at buying a 99 GC Laredo. Transmission question Mike Diaz ZJ Grand Cherokee Forum 4 03-14-2005 06:27 PM
Just looked at the '05 - UGH. briandunning ZJ Grand Cherokee Forum 22 12-06-2004 03:42 PM
