Brake Problem - JeepForum.com
post #1 of 10 Old 07-29-2009, 04:53 PM Thread Starter
GrandJoker
2009 JK Wrangler
Brake Problem
i have a 93 ZJ and brakes will not grab idk why i think maybe master cyclinder but i dont know can anybody point me in the right direction
GrandJoker is offline
post #2 of 10 Old 07-29-2009, 05:04 PM
Bama_WJ
Bama_WJ's Avatar
Hows the pedal feel? Any leaks anywhere? How old are the rotors/pads (or drums/shoes if they are in the rear)?
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #3 of 10 Old 07-29-2009, 05:14 PM Thread Starter
GrandJoker
2009 JK Wrangler
The pads and shoes are all new and the rotors just got turned and as long your not moving the pedal is hard but when your moving its goes soft
post #4 of 10 Old 07-29-2009, 05:21 PM
kevo94zj
1994 ZJ
check your brake lines for leaks ...
good luck
kevo94zj is offline
post #5 of 10 Old 07-29-2009, 05:23 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
have any hissing coming from that area of the dash?
ratmonkey is offline
post #6 of 10 Old 07-29-2009, 08:14 PM Thread Starter
GrandJoker
2009 JK Wrangler
thats just the thing theres no hissing and there are no leaks
post #7 of 10 Old 07-29-2009, 08:32 PM
SnowLeopard
I'm having issues along this line as well. I've been told that if it's not the master it might be the proportioning valve. I'm taking it in to be checked next week. I'm not savvy enough with the mechanical stuffs to work on my own brakes. I like living too much.
If this thread's still about, I'll give an update here when I get info from the shop. Hopefully it will be of some help to the OP. It's crazy how the brakes just seem to become soft when everything appears to be in order. I don't understand it.
SnowLeopard is offline
post #8 of 10 Old 07-29-2009, 08:40 PM Thread Starter
GrandJoker
2009 JK Wrangler
yea i know tell me about it but i replace my proportioning valve and it didnt really help much but plz let me know what they says
post #9 of 10 Old 07-29-2009, 08:52 PM
SnowLeopard
Well, he just tested out the brake pedal while it was in park, so that doesn't help much. He'll have to actually take it out and drive it, then go over all the various bits and pieces to see what's up. He just mentioned it 'could' be the proportioning valve. I've even heard, in another thread on JF, that the brake lines are rubber and can get old so that they expand when you press the brakes, softening the response of the brakes. Who knows in the end? It's like everything else with Jeeps, it's always got 50 possible causes and usually turns out to be the last one you test out. Process of elimination is key.
post #10 of 10 Old 07-29-2009, 08:56 PM Thread Starter
GrandJoker
2009 JK Wrangler
yes i know lol there great vehicals but so complicated but i have heard that to but there really aint a way to check it. is there?
Brake or ABS problem... Chuwee ZJ Grand Cherokee Forum 3 01-19-2010 03:29 PM
brake problem TslAtticus ZJ Grand Cherokee Forum 13 11-09-2007 11:44 AM
Brake Problem! AWILD ZJ Grand Cherokee Forum 8 01-17-2006 01:45 PM
brake problem K-Pax ZJ Grand Cherokee Forum 10 12-11-2004 10:49 PM
brake problem jrakul ZJ Grand Cherokee Forum 4 04-08-2004 01:44 PM
