Brake Pedal Kickback - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Brake Pedal Kickback
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectSavvy Aluminum Gas Tank SkidFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 08-23-2014, 08:23 AM   #1
WoodyXJ
1994 ZJ
On my 94 I get a weird kick back in my brakes and a sudden stop. It's only while the pedal is depressed and going slow, like 5mph and under. The typical ABS noises. Sometimes when I hit a little bump, other times on totally flat ground. Totally random as far as I can tell. It is fairly frequent though. Brakes have been manually bled, and fluid is topped off.
Any ideas or do I just need to start throwing parts at it? I'm sure sooner rather than later I will need to replace most if it, the previous owner was not too keen on maintenance other than oil changes... I would like to solve this current issue asap though
WoodyXJ is offline   Reply With Quote
