brake pedal going to the floor!! - JeepForum.com
post #1 of 8 Old 12-19-2011, 06:23 PM Thread Starter
Dustem
1994 XJ Cherokee
Hello, I need help on my 1994 grand cherokee. Back brake shoes have 2000 miles on them. Front pads about 1000 miles since replaced. New wheel cylinders and drums on the back and rotors on the front. I have inspected all brake lines and hoses for leaks. Brake fluid level is fine. Three out of five times the pedal will go to the floor real slow when stopping. Brake light comes on and it will start rolling! You can let off the brake and sometimes it will hold, sometimes it wont. Does the same thing in neutral. Vaccum is good to the booster. Dont know what the small round cylinder is that the brake lines go to out of the master cylinder. It also has two rubber lines. Thanks GB
Dustem is offline
post #2 of 8 Old 12-19-2011, 08:43 PM
RTYauch301
sounds a bit like the master cylinder is gone but you said it has new wheel cylinders... did you bleed them properly may just have air in the lines
RTYauch301 is offline
post #3 of 8 Old 12-19-2011, 09:04 PM
edpmedic
Did you loose all the fluid when you changed the cylinders. If you lost the fluid in the master it needs to be bled. I would then go to the right rear and stick a tube on the blender screw. Stick the other end into a clear jar with brake fluid. Then pump the pedal and look for air bubbles. Repeat on left rear. Then right front then left front.
I use a mighty vacuum with the bleeder system they sell them at autozone or pepboys worth every penny. If no air and abs light is not on and if it goes to floor. Then you pump it up and had your foot on it and slowly goes down I would then say it is the master.
I am sure the emergency brake and the shoes are adjusted properly.
Never4get those who gave their lives on 09-11-01 WTC and Pentagon. FDNY-EMS-NYPD-PAPD. Also those who are still dying.
_______________________________________________
"Freedom is never voluntarily given by the oppressor; it must be demanded by the oppressed."
Martin Luther King, Jr.
"Always aim at complete harmony of thought and word and deed. Always aim at purifying your thoughts and everything will be well."
Mahatma Gandhi
Feel the Sunshine on your face
edpmedic is offline
post #4 of 8 Old 12-19-2011, 09:59 PM Thread Starter
Dustem
1994 XJ Cherokee
I have recently moved and could not find my tool that you pump to pull the air out of the lines. I did push a little fluid out of the front of the master cylinder when doing the front brakes so I added fluid as I bled them. I took my time bleeding both ends by pumping the pedal but maybe I need to use the bleeder to make sure all air is out. When using the vacuum tool I think I am suppose to push and hold the brake pedal in just about 1 to 2 inches? Is that correct? I will give it a try. If it is air I still dont understand why it took this long to be a problem. Your help is greatly appreciated. Thanks, GB
Dustem is offline
post #5 of 8 Old 12-20-2011, 09:05 AM
RTYauch301
if it didnt do it right away then im 98% sure your master cylinder has failed
post #6 of 8 Old 12-20-2011, 11:37 AM Thread Starter
Dustem
1994 XJ Cherokee
Thanks for all the help!
Dustem is offline
post #7 of 8 Old 12-21-2011, 07:53 AM
edpmedic
I agree with that. I would look for signs of the power
booster being wet or move the mat under the dash and look for signs of floor being wet. That's if it is leaking out. If you said your not losing fluid its internal. Like I said if you sit there and have a good pedal. Then it bleeds down most likely the master. If the pedal is spongy and it pumps up and gets hard usually then its air.
Sorry for spelling and grammar I'm doing this on my phone and I it doesn't word wrap. Its like one continuous line...got to figure why it does that.
Mahatma Gandhi
edpmedic is offline
post #8 of 8 Old 01-10-2012, 02:27 PM Thread Starter
Dustem
1994 XJ Cherokee
Brake trouble
Bled the brakes with 'tool' and nothing changed. Took all three plugs (electrical)loose from brass fitting that brake lines go to and ABS motor. Drove Jeep and problem quit. Then I unplugged the long rectangle plug on a box mounted on the drivers inner fender. It is a brake control box. I guess I reset some kind of problem but it is O.K. for now. I have drove it about 200 miles with no brake issues. Thanks for all the input and help, GB
Dustem is offline
Intermittent Brake Pedal Goes to the Floor res0n0xg ZJ Grand Cherokee Forum 6 06-01-2011 02:10 AM
Brake pedal to the floor on hard stops.... dours01 ZJ Grand Cherokee Forum 2 01-17-2010 02:38 PM
Brake problems, grinding, pedal dropping to floor Stayinalive ZJ Grand Cherokee Forum 8 12-17-2009 10:37 PM
Brake pedal on Floor on incline/declines, Time to upgrade???? ramsport59 ZJ Grand Cherokee Forum 4 05-31-2009 02:39 PM
brake pedal went to floor board? JeepCherk98 ZJ Grand Cherokee Forum 11 09-16-2008 09:12 AM
