Brake Line Size/Diameter - JeepForum.com
post #1 of 8 Old 11-03-2009, 06:06 AM Thread Starter
Krayzie949
I'm sorry I couldn't really search for this information, but I was wondering if anybody could tell me the brake line size/diameter for a 1996 Jeep Grand Cherokee Laredo with the 4.0L. If you can I'd appreciate it. Thanks.
Brian
2001 Jeep Cherokee 4.5" RE Superflex Lift
1970 Buick GS 455 Stage 1 4-speed
1977 Trans Am (original owner)
Krayzie949 is offline
post #2 of 8 Old 11-03-2009, 09:47 PM Thread Starter
Krayzie949
Anybody??? I need the rear brake line size...
post #3 of 8 Old 11-03-2009, 11:07 PM
Tiggerrrrr
uhmm... measure it?
'95 ZJ Limited 4.0
2.25" BB , 31 10.5 15 Treadwright MTG's on Black Rock steelies
Everything "pimpin' Gold" REMOVED!
Looking for a REAR tow hook and bracket!
Tiggerrrrr is offline
post #4 of 8 Old 11-04-2009, 03:15 PM Thread Starter
Krayzie949
Originally Posted by Tiggerrrrr View Post
uhmm... measure it?
Uhmm... I'm buying this Jeep and the person I'm buying it from said if I find out what diameter they are he will put new ones on it. The Jeep is an hour from my house and I'm not driving up there just for that, not if I don't have too.
post #5 of 8 Old 11-04-2009, 09:19 PM
oldfamilyguy
If the guy doing it can't figure that out himself I wouldn't trust him to check my oil, never mind new brake lines.
oldfamilyguy is offline
post #6 of 8 Old 11-04-2009, 10:13 PM
Travis873o
just go to the parts store and ask for the line. then measure it if you want or they might have the specs.
FOR SALE: ZJ 231 bezel. 1996 ZJ Lifted
Travis873o is offline
post #7 of 8 Old 11-04-2009, 10:37 PM
colt808
If you mean the brake plumbing (steel tubing), it's 5/16"...I just re-did mine.
However, I'd have to agree with oldfamilyguy on this, I wouldn't trust the guy to change the line. He has the vehicle and couldn't just take a quick look for himself? Unless the lines are seriously jacked up causing it to be unsafe to drive home, you should do it yourself. All you need to do is measure the length required and have the parts store cut it for you. While you're there, pick up a quart of DOT3, some new fittings and borrow a hose flare tool. If you're not sure, you can always pull the line you want to replace and do it all at the parts store. Then all you have to do is re-attach the line, then flush and bleed the system. <----not optional
colt808 is offline
post #8 of 8 Old 12-26-2011, 09:06 PM
TallyZJ
Dragging this back up because I was searching and noticed this last post.
Brake lines, the hard lines, are 3/16" diameter, not 5/16".
A 5/16" diameter hard line would be equivalent to an 8mm diameter line which is hugimongous.
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
TallyZJ is offline
New calipers/brake line/pads, bled brakes, now i have no brake pressure! klwong1 ZJ Grand Cherokee Forum 13 11-16-2013 09:15 PM
Lowest steel line on frame rail, very rusty, brake line? ktmjeepguy ZJ Grand Cherokee Forum 12 10-08-2011 10:47 PM
diameter of metal brake lines? pittbug ZJ Grand Cherokee Forum 4 10-18-2009 09:49 AM
Brake line pic for WJ nierace ZJ Grand Cherokee Forum 0 07-24-2008 02:52 PM
new wheels/tires does it matter what size the diameter is???? Hummer2Rescue ZJ Grand Cherokee Forum 2 05-22-2007 10:33 PM
