Brake Lights don't work - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Brake Lights don't work
Rough Country Lift Kits and Parts!Bds fox ipf 2.0 racing series shocks now available at rock20 Ton Press Brake DIY Builder Kit @ Swag Off Road
Unread 05-06-2006, 09:45 PM   #1
bost1217
2004 Grand Cherokee Limited 4.7HO. Brake Lights dont't work at all. I can not find the fuse for that brake light circuit. It's not listed in the manual or of the fuse block cover. Everything else electrical works. They just all of a sudden stop working. Al other lights are working fine. Please help!!! My wife is getting mad!!!
bost1217 is offline   Reply With Quote
Unread 05-06-2006, 10:03 PM   #2
pro street jeep
1985 XJ Cherokee
have the same problem with my 96 what i think could be is the box that is in the left side cubby hole in the rear. when mine does it i have to unplug it and wait a few then plug it back inthen they work i guess it resets its self. try that and see what happens.
pro street jeep is offline   Reply With Quote
Unread 05-06-2006, 10:43 PM   #3
GreenDean
bost1217:
it could be something as simple as a bad switch with is located on the pedal. however, the WJ's have a body computer that all light controls run threw (along with the seat, windows, locks and anything else power)... so it might be a more of a pain in the butt then that. the dealership can actually just plug a computer into the jeep and it will tell them the exact source of the problem.
pro street jeep:
The ZJ's are not as complicated.
Maybe that connector you unplug is bad and your repluggin it fixes the problem temporarily.
GreenDean is offline   Reply With Quote
Unread 05-07-2006, 06:32 AM   #4
bost1217
I opened up both tail light housings and found the passanger side one to have water in it. The bulbs are good but the metal strips that carry the power to the lights were rusted. Is there a fuse I can check. I looked in the book and on the fuse box. Nothing says "Brake lights"
Unread 05-07-2006, 04:32 PM   #5
bost1217
The end result was a bad switch at the brake pedal. Thanks.
Unread 05-07-2006, 04:46 PM   #6
greasefingers
1994 ZJ
Way to go BigDean! Another 2004 with issues. Man that makes me mad.
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
Unread 05-07-2006, 05:49 PM   #7
SteelBlue_WJ
SteelBlue_WJ's Avatar
do the rear parking lights work still and the brakelight turn off when the brakes are used with the headlights on? of do they just flat out not work?
Bobby
2001 Steel Blue WJ Laredo SA 4x4, 3.5" lift, Apperance Package with factory Laredo Steel Blue cladding/leather
Conferr Roof Basket with custom Randy Ellis Design light cage, WAAG grille guard and Hella lots of 500 lights
2004 Wrangler Sport, 2.5" and 31's, nothing special
"For all sad words of tongue and pen, the saddest are these, 'It might have been.' "
John Greenleaf Whittier
SteelBlue_WJ is offline   Reply With Quote
