Brake light works; tail light doesn't - JeepForum.com
post #1 of 10 Old 09-12-2008, 08:09 PM Thread Starter
manofmany
It was vice versa before I swapped a new bulb in. My tail light on the drivers side will not illuminate but the brake light will. What in the world could that be? The socket maybe? Can I get just a new socket somewhere?
1998 Cherokee 4.0L
1999 Grand Cherokee Limited 4.7L
manofmany is offline
post #2 of 10 Old 09-12-2008, 11:20 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
on the wj?
it'll either be the seating of the socket or the whole assembly is bad.
ratmonkey is offline
post #3 of 10 Old 09-13-2008, 12:21 PM
Grdaemon
Grdaemon's Avatar
It's a ground thing. Sandpaper.. all contacts..done!
X-Cherokee 1991 Limited Hunter Green
Now 1999 WJ Limited 4.7
Bright Platinum Metalic Clear
Grdaemon is offline
post #4 of 10 Old 09-13-2008, 12:28 PM
stewco
Buy new sockets
Had the same problem..... I sanded them first, worked for a while, then quit again. Replaced sockets, problem solved.
stewco is offline
post #5 of 10 Old 09-13-2008, 02:49 PM
elmer_fud
could you bend the contacts in the socket up?
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #6 of 10 Old 09-13-2008, 05:05 PM Thread Starter
manofmany
Hmm one of the contacts did look a little burnt. I'm gonna try going at it. I see a replacement on ebay is like $12 shipped. Not bad.
1998 Cherokee 4.0L
post #7 of 10 Old 09-14-2008, 06:44 AM
Grdaemon
Grdaemon's Avatar
They were too tight so I didn't try anything myself..
Grdaemon is offline
post #8 of 10 Old 09-14-2008, 09:13 PM
ZJcrawler45
wait... can i replace the sockets on my zj? i have the same exact problem for about a year now and always thought i had a faulty wiring harness... where do i get just a socket at.? Also when it first stopped working something was burnt black in the socket at the bottom of the bulb.
Captain Nate
ZJcrawler45 is offline
post #9 of 10 Old 04-03-2010, 06:02 PM
wwwired
Common Tail Light works - Running Light doesn't problem
The reason for this is that the bulb socket is rotated 180 degrees out of position. The contact points need to be properly aligned (notice there are two contacts on one side and one just one contact on the other side). In the picture below you can see the two silver contact points on one side. The other side (behind and out of view in the picture) has just one:
The bulb unit (a twist in twist out circular unit with a fin that has a notch on one side of the top of the fin cut away) has three contact points for the dual running-light and brake-light circuit. Notice the notch on the bottom left in front of his thumb.
If you look at the lens socket into which the bulb unit is twisted, you'll see it also has three contact points (one on one side and two on the other side).
A common mistake is to insert the bulb unit the wrong way in (rotated 180 degrees). The side with the two contacts on the bulb unit has to line up with side on the lens socket's seat with the two contact points. Likewise the bulb unit side with just one contact point has to line up with the side on the lens socket's seat with just one contact.
You should have three bulbs in each tail light. The two bottom lights will have the fin-notch on the upper side I believe. The fin-notch on the inserted bulb socket for the top light (that contains the combination running-light and brake-light) will face the opposite direction from the two bottom bulb sockets.
wwwired is offline
post #10 of 10 Old 08-20-2012, 10:50 PM
BigWheel7
I first thought i had the sockets in wrong as well but the more i looked at it i found they were in correct. I think i have it narrowed down on mine to the sockets are just not making contact with the metal tabs in the lights. Keep in mind these are brand new lights and sockets.
BigWheel7 is offline
tail light not working - brake light does work gd929 ZJ Grand Cherokee Forum 2 06-17-2010 12:29 AM
Problem With Tail?brake Light semperfismhs ZJ Grand Cherokee Forum 8 01-22-2009 12:09 PM
Tail Light Doesn't work, brake light does? venterminator ZJ Grand Cherokee Forum 0 08-04-2007 07:58 AM
Tail light and Brake Light Question Thedjgtc ZJ Grand Cherokee Forum 2 10-10-2006 02:43 PM
brake/ tail light problem darnelled ZJ Grand Cherokee Forum 11 06-13-2005 08:16 AM
