Brake Light Switch Installation - JeepForum.com
post #1 of 12 Old 05-22-2006, 07:04 PM Thread Starter
JeepMax
Hi,
All brake lights on my '99 WJ won't work. I checked the fuses - and all of them are OK. So I figure that it must be the brake light switch that has gone bad.
How do you take out the old switch?
I cannot figure out how to take the pin that presses against the pedal out of the bracket.
Does anyone have a shop manual?
Thanks!
Max
'99 WJ Grand Cherokee Laredo
JeepMax is offline
post #2 of 12 Old 05-22-2006, 07:06 PM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
By any chance did you check for power at the switch? I think I would before I take the switch out.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #3 of 12 Old 05-22-2006, 07:10 PM Thread Starter
JeepMax
No - I have not checked the power - but I am pretty confident that it does have juice since all fuses are good. Could it be something other than the switch?
JeepMax is offline
post #4 of 12 Old 05-22-2006, 07:14 PM
michiganmaveric
Got Beer?
2011 JK Wrangler
Yes. Recently there have been some posts here about the tail light assy's going bad themselves. I would check for power at the switch, and if I had it check for power at the tail light assy itself.
Also, You said nothing about checking the bulbs.
Lifetime member #13
post #5 of 12 Old 05-22-2006, 07:17 PM Thread Starter
JeepMax
I agree that could be the case. I will definitely check power. My taillights are working fine though and I would doubt that all three brake lights would go bad at once (bulbs are fine).
Can anyone give advice on how to remove that brake light switch (white plastic box)?
Thanks!
JeepMax is offline
post #6 of 12 Old 05-22-2006, 07:22 PM
michiganmaveric
Got Beer?
2011 JK Wrangler
If I am not mistaken, there are two switches for the brake lights. One for the two main lights and a seperate one for the third light.
Lifetime member #13
post #7 of 12 Old 05-22-2006, 07:27 PM Thread Starter
JeepMax
There is only one switch for the brake lights - this is the mechanical switch that presses against the brake pedal.
JeepMax is offline
post #8 of 12 Old 05-22-2006, 07:30 PM
michiganmaveric
Got Beer?
2011 JK Wrangler
OK ten characters
Lifetime member #13
post #9 of 12 Old 05-23-2006, 04:36 PM
michiganmaveric
Got Beer?
2011 JK Wrangler
Any luck on getting your problem fixed?
Lifetime member #13
post #10 of 12 Old 05-24-2006, 06:59 PM Thread Starter
JeepMax
Yes thanks. I got a new brake light switch @ Autozone for 11.99. Was real easy to install (turn a little counterclockwise and it came right off). Only hard part was trying to get off the electrical plug - was really tight. Brake lights work like a charm now...
JeepMax is offline
post #11 of 12 Old 05-24-2006, 07:39 PM
michiganmaveric
Got Beer?
2011 JK Wrangler
Great, glad it was only the switch.
Lifetime member #13
post #12 of 12 Old 07-09-2011, 09:15 AM
Clark Kent
Thanks for the help 5 years later
Your post of 5 years ago did the trick. I couldn't figure out how to remove the break light switch. I searched the web for 2 hrs. and finaly found your post on how to get the switch out.
Thanks. Now I hope that is the problem.
Everything else check out fine.
If God had wanted us to drive Jeeps he would have given us more MONEY!
Clark Kent is offline
Brake Light switch HurriJeff WK Grand Cherokee & XK Commander Forum 0 05-04-2009 07:13 PM
99 Grand Cherokee brake light switch steveandtracy7 ZJ Grand Cherokee Forum 1 03-05-2009 04:27 PM
Brake Light Switch!!! ajl5076 ZJ Grand Cherokee Forum 2 06-24-2008 09:59 AM
Brake light switch/speed control a70eliminator ZJ Grand Cherokee Forum 0 01-31-2008 04:18 AM
Need help with Brake Light Switch 01SolarYellowTJ ZJ Grand Cherokee Forum 3 08-29-2005 07:37 PM
