Brake Issues Question - Page 2 - JeepForum.com
post #16 of 17 Old 03-06-2014, 09:41 AM
Uniblurb
Uniblurb's Avatar
Kinda figure it wasn't a hose/line that blew Adam when you said in your 1st post your brake fluid has been leaking for a few days at a "steady rate". When a hose blows it goes quickly. Glad you have the MC/booster changed out and can get it to that shop for bleeding.
When I twisted the check valve on my booster out of the way for replacing my header that's where I ended up with a vacuum leak and know another where it did the same thing. You wouldn't think a reman booster would leak there but I just ended up putting some RTV around the outside check valve where it meets the metal and problem solved. You're welcome for the advice and good luck!
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 96 4.0 XJ (son's)
Uniblurb is online now
post #17 of 17 Old 03-06-2014, 10:17 AM Thread Starter
Adamzero
yeah, I'm pretty sure its coming from the valve. I didn't have someone with me with I noticed it so I was hitting the brakes running around the door and listening haha. I will for sure know today though.
Adamzero is offline
brake , fluid , issues , leak , zj
