03-04-2006, 12:23 PM
#1
How do I get these darn things off? I am used to Ford calipers and I don't have a service manual yet.
I jacked it up, took the wheel off, and then undid the 2 13 mm bolts in the back. After I did that the rotor and the caliper was loose but I just couldn't pull the caliper off of the rotor. Any help?
'97 ZJ Laredo - Gone
03-04-2006, 12:26 PM
#2
I ate what?
I think there is three bolts...I can't remember on a ZJ, but look very carefully to see if you can find a third bolt maybe underneath. If there isn't one, then use a rubber mallet and smack a couple of times and it will break it loose.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
03-04-2006, 12:31 PM
#3
No where near stock
there are just two bolts. What you may have to do is compress the piston a little to get enough play to remove the caliper and pads.
Nathan
One slightly modified '96 ZJ
new sig coming soon
03-04-2006, 12:37 PM
#4
 exactly
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
03-04-2006, 01:01 PM
#5
Only 2 bolts. Normally when I remove the botton bolt I will loosen the top 1 that knock it loose with a hammer, once free'd remove the top bolt and it comes off quite nicely
[url=http://www.mazdaworld.net/forums/index.php?showtopic=19]"Within the mind lies the greatest of all evils...Eternity" - Enigma02S[/url]
[url=http://www.cardomain.com/ride/2370949]2000 Millenia S...Five figure spending account[/url]
[url=http://www.cardomain.com/ride/2384051]1998 Jeep Grand Cherokee...Gone but never forgotton[/url]
[url=http://www.cardomain.com/ride/2383985]2003 BMW M3 SMG...For Sale, PM if interested[/url]
[url=http://www.cardomain.com/ride/2484240]2000 "Jeep Grand Cherokee...4.7, Quadra-Drive, Loaded.[/url]
"A dark and bitter chill fills the air. once thriving life wallows away into ash as he slithers past, the very stars themselfs part to make way for his haunting, yet oddly claim arrival. Bhr approaches." - Hatter
"But i have to say, BHR's rants go hand in hand with moring coffee to get my day started - RXL"
Admin - [url]http://www.mazdaworld.net[/url]
03-04-2006, 01:04 PM
#6
Ok thanks guys. Sorry for the newb question. I am still pretty new to the Jeep scene.
03-04-2006, 01:12 PM
#7
No where near stock
no problem. But it is normal when dealing with disc brakes that you use a large screwdriver/prybar to free the caliper up some to be able to remove it easily. It is something that you just get used to after a while.
Nathan
new sig coming soon
03-04-2006, 01:31 PM
#8
It is very common, it is a good sign that the brake system is working well with no leaks.
1994 ZJ - 4.0 - 242 - 4.5" RE lift - 32" Maxxis Bighorns - 4.11 gears - Super 35 axle - Ected lockers front and rear - On Board Air - JKS Quicker Disco's - ARB front - engine/TC/Gas tank skids - home made sliders - a little of Kevins stuff
03-04-2006, 02:32 PM
#9
Oh yeah, I wanted to ask you guys how you compress the piston. I am not sure where I should place the C clamp. On my Mustang, I could just wiggle it enough and it would slide off.
03-04-2006, 02:50 PM
#10
No where near stock
if you haven't gotten the calipers off yet use a large flat blade screwdriver or prybar. You place it so you can apply pressure between the rotor and pad on the psiton side and pry. This will compress the piston just enough to be able to remove the caliper. Then use your c-clamp to compress it the rest of the way.
Nathan
new sig coming soon
03-04-2006, 02:55 PM
#11
Wow, you're on top of things Varkyl. Thanks again.
Nope haven't tried again today. Getting pretty cold out now. Tomorrow morning I will get them done.
03-04-2006, 03:10 PM
#12
woo hoo, Now I'm a JF supportor.
anyway, I actually have a piston compressor. basicallys its 2 flat metal hands you place inbetween 2 pads and screw like a clamp at the bottom. Opens each side the same amount, quick and easy. 5 bucks any autoparts store.
