Brake booster problem on zj - JeepForum.com
post #1 of 6 Old 09-05-2012, 08:41 PM Thread Starter
shalezzz
Just recently bought a 97 zj i6 disc all around and the brake pedal is hard as a rock and takes more effort than it should to stop. However it does stop.
The check valve works. The line leading to the check valve works.
When I pump the brake to release the vacuum and start the engine with my foot on the pedal, the pedal does drop slightly. The pedal makes a woosh as I press it but does not continue after the initial press.
The only test I haven't done is take a vac gauge to the line.
Theres nice pedal travel at idle in stop and go traffic.
My question is if the brake booster is at fault could it still hold vacuum and work slighty? Or are there other problems that could lead to this thanks
shalezzz is offline
post #2 of 6 Old 09-06-2012, 06:56 PM
jnicewan
Yes the booster can still hold a vacuum and work slightly or not at all. The diaphragm could be torn or have a hole in it and when you press the pedal the atmospheric valve releases vacuum on one side of the booster but since the diaphragm is faulty you will have no or low assist, basically its just making a vacuum leak when pressing the pedal.
jnicewan is offline
post #3 of 6 Old 09-07-2012, 02:47 PM Thread Starter
shalezzz
Thanks any expierence with replacemtent brake boosters? I don't know if I should get one from the junkyard and hope it works or buy an a1 cardone vs crown vs omix-ada
shalezzz is offline
post #4 of 6 Old 01-15-2014, 01:08 AM Thread Starter
shalezzz
UPDATE: replaced pads and booster braking effort is reduced greatly.
however at idle i still have to keep my foot sorta hard on the brake to prevent it from rolling away. harder then what i would prefer. i think i have to do a vac test at idle idk?
shalezzz is offline
post #5 of 6 Old 01-15-2014, 02:01 AM
Uniblurb
Uniblurb's Avatar
So have you tested the brake booster rubber grommet where the intake hose attaches to make sure it isn't leaking? When I just turned it out of the way when installing a new header when I turned it back to the correct position it leaked. Know another this same thing happened to and RTV around the grommet where it goes into the metal housing solved the problem.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is offline
post #6 of 6 Old 01-16-2014, 03:14 PM Thread Starter
shalezzz
It's a brand new booster but I'll check and I'll have to check on the intake mani
shalezzz is offline
brake booster? siklas ZJ Grand Cherokee Forum 2 02-22-2010 09:52 AM
Power Brake Booster problem? BlackDaddyZJ ZJ Grand Cherokee Forum 1 08-21-2009 07:03 PM
Repaired leaking brake power booster, but now brake lights are on all the time MNWJ ZJ Grand Cherokee Forum 2 05-11-2009 07:59 AM
Brake booster went bad (WJ) allenc ZJ Grand Cherokee Forum 1 11-02-2006 04:53 PM
brake booster? rrubio ZJ Grand Cherokee Forum 47 07-10-2006 11:11 AM
