Bout to buy a 5.9.Common things to look out for? - JeepForum.com
post #1 of 7 Old 02-05-2013, 02:30 PM Thread Starter
fljeepney
Found a stone white niner for a $1000 and need to know what common problems would I run into?It has 189xxx miles and runs great.
1993 ZJ 4.0 Laredo
1998 ZJ 5.9 Limited
1985 Corolla AE86 coupe
fljeepney is offline
post #2 of 7 Old 02-05-2013, 02:43 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
The usual ZJ stuff. I don't think there many problems that are specific to niners other than the efan. Check out my build thread if you want to see a high mileage niner with every problem in the book haha.
McCloud's Niner Build/Rebuild
In the garage: M1 4bbl
McCloudsZJ is offline
post #3 of 7 Old 02-05-2013, 04:34 PM Thread Starter
fljeepney
You sure did alot to your demon and to me it's worth it.I hope I can restore mine with it needing climate control panel,dash pieces,and a good cleaning inside and out.
1993 ZJ 4.0 Laredo
1998 ZJ 5.9 Limited
post #4 of 7 Old 02-05-2013, 04:44 PM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
You might want to check out thespeedfreaks.net. It's a forum that's pretty much 5.9 specific. Lots of good information there. Lots of people that know way more than me, too.
Sent from my iPhone 6 using JeepForum
post #5 of 7 Old 02-05-2013, 05:00 PM Thread Starter
fljeepney
Ok thanks!I will do that and I hope you get yours the way you want it.
1993 ZJ 4.0 Laredo
1998 ZJ 5.9 Limited
post #6 of 7 Old 02-05-2013, 07:49 PM
SpenceAK
Make sure you got oil pressure when engines warmed up at idle haha. I bought mine and didn't notice this issue until I got to my house! Replaced pump and same issue verified with mech gauge but its not a common problem just make sure to check everything because you don't know how the PO maintained it. But I have no problem yankin the engine for a rebuild
SpenceAK is offline
post #7 of 7 Old 02-05-2013, 07:58 PM Thread Starter
fljeepney
Gotcha.Thanks!
1993 ZJ 4.0 Laredo
1998 ZJ 5.9 Limited
