Bought a new Jeep, few problems. Need Help! - JeepForum.com
post #1 of 5 Old 09-26-2011, 11:34 PM Thread Starter
95GrndChrkLmtd
So I bought a 1995 Jeep Grand Cherokee Limited with 180,000k. 4.0L 2 days ago for 1000$, and I did a full tune up on it (plugs/wires/cap/rotor/fuel filter/air filter/oil change) and I'm still having a few problems. My oil pressure gauge is all over the place. My temperature gauge is fine, except everytime i hit the gas it drops right down to 0, soon as I let off it goes bback up instantly. My infinity gold CD player in it is a little mixed up, I hit 1 button and sometimes it does the right function, or instead does the function of the button right below it. And also it idles at 500 RPM, but it idles fine when im driving, other than when I'm stopped at lights and stuff it idles rough. Any ideas guys? Sorry for all the questions.
I'm Riley, and I'm new to the forum.
Thanks
95GrndChrkLmtd is offline
post #2 of 5 Old 09-27-2011, 04:06 PM
JeepFreak1982
New sending unit for the gauge, new stereo, temp gauge sounds like an electrical problem someplace maybe just the sensor, the idle is probably a dirty IAC maybe a failing TPS. Wouldnt hurt to replace em both. 180K and 17 years is a long time for anything.
JeepFreak1982 is offline
post #3 of 5 Old 09-27-2011, 04:09 PM
PolkaPower
I think it's normal for the oil pressure gauge to rise and fall a bit with engine speed especially after start up it will be lower. Mine fluctuates between 35 and 50 or so.
PolkaPower is online now
post #4 of 5 Old 09-27-2011, 04:11 PM
JeepFreak1982
Yes it will fluctuate some but not from 0-30 + lbs. It should never fall to 0 unless you have a problem.
post #5 of 5 Old 09-27-2011, 04:51 PM
TheHalfWit
I'd say replace the oil pressure sender, and the temp gauge sender. Since its a 95 the temp gauge sender is located on the *** end of the block, under the wiring from the injectors with about 5mm of space to play with. (You get two senders with the 93-95 zj's, one is in the water outlet tube where the thermostat is, and is for the computer. The other is right in front of the firewall towards the back of the block. Removal is easy if you have a 1/4 ratchet and the right socket break off plastic bit and unscrew the copper plug, but installation is a PITA.)
Normal range for the oil sender I'd say is 40-70 when cold, then 20-45 when warm. It will climb when you hit the gas, and fall when you idle. If its all over the place replacement is a 5 minute procedure, the oil pressure sender costs about 30 from NAPA or 15 bucks from rockauto.
Calm. C.
If a week goes by without needing to replace something, pinch me because I must be dreaming.
TheHalfWit is offline
infinity gold , oil pressure , rough idle , temperature gauge
***help Just Bought A Jeep***** ecproductions ZJ Grand Cherokee Forum 13 07-02-2008 05:46 AM
?????*****help Just Bought Jeep*****???? ecproductions ZJ Grand Cherokee Forum 0 06-29-2008 01:51 AM
Just bought a jeep some problems....HELP? Grazsrootz ZJ Grand Cherokee Forum 6 05-22-2007 10:09 PM
Bought a new 99 WJ GC problems.. axle or cv? koocuz ZJ Grand Cherokee Forum 13 07-31-2006 12:05 PM
Bought Grand Cherokee. Have a few problems. rollerbones ZJ Grand Cherokee Forum 15 12-31-2003 06:26 AM
