bought IRO 3.5 lift and just received them but the coils say xj 4.5 coils will they.. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > bought IRO 3.5 lift and just received them but the coils say xj 4.5 coils will they..
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBuild your Dream Jeep with Poison Spyder's Interactive GarRuffStuff Memorial Day Sale!
Unread 12-06-2008, 03:56 AM   #1
stiller
fit my 95' zj 4.0
like its a small sticker on the box tht says xj 4.5 coils but i ordered the zj 3.5 package. If its not some small rnadom print error will those coils fit or would i haveto return them or something? and theyr front coils btw
stiller is offline   Reply With Quote
Unread 12-06-2008, 04:06 AM   #2
newfieZJ
Jeep collector
newfieZJ's Avatar
I have TJ 4.5 springs on mine , yields 3.5" with the V8 . I`d double check with IRO to be sure , alot of Jeep parts are interchangable , springs being one . XJ & ZJ being so close in design I`d think they would give a 1/2'" more with the 4.0 , and lift you 4 inches on the frt . I`ll be curious to know if IRO made a mistake or if theses are indeed the springs they use in the kit . double check for sure before installing , unless someone chimes in and says this is the norm
newfieZJ is offline   Reply With Quote
Unread 12-06-2008, 04:58 AM   #3
Jones
Consider the following...
Jones's Avatar
I believe XJ 4.5" springs yields 3.5" for the ZJ. Double check with IRO though.
Put your bacon where your mouth is!
Jones is offline   Reply With Quote
Unread 12-06-2008, 10:02 AM   #4
BlackShuck
I'm pretty sure IRO uses another Jeep model's (TJ?) rear springs for the springs in their 3" IRO WJ kit. So reading what you posted don't overly surprise or concern me. But like mentioned above, it doesn't hurt to check.
01 WJ Spec. App. Laredo. Retrofitted with Akebono calipers; Stillen Sport Rotors; Reese Class III Hitch; and a ZJ Front Drive Shaft
Save yourself time, money, and a lot of frustration by NOT shopping at JcWhitney!!
Utah Jeep Crew #8
FS: Rear wind deflectors || || Stock OEM Air Box Set Up
BlackShuck is offline   Reply With Quote
Unread 12-06-2008, 12:02 PM   #5
MoonyJohn
Jackstand Crawler
MoonyJohn's Avatar
Give them a call. They would be glad to help you out.
ZJ - Sold
WJ- Sold
JK - :)
Oregonian Native
MoonyJohn is offline   Reply With Quote
