Bought Grand Cherokee. Have a few problems. - Page 2 - JeepForum.com
post #16 of 16 Old 12-31-2003, 06:26 AM Thread Starter
rollerbones
Originally Posted by RockPaws
If its neither the IAC or TPS, I would take it some where and have the computer checked. I do not like throwing parts at a problem to see what fixes it. (we call it "Shotgun Maintenance").
Here is what the PCM looks at idle mode, at operating temp (closed loop). Inputs to the PCM:
1) A/C select signal
2) A/C request signal
3) Battery voltage
4) Crankshaft position sensor
5) Eng coolant temp sensor
6) Intake manifold air temp sensor
7) Manifold absolute pressure (MAP) sensor
8) TPS - throttle pos sensor
9) Camshaft position sensor (is distributor)
10) Park/neutral switch
11) O2 sensors
Based on these inputs - voltage is applied to the fuel injectors with the ASD relay via the PCM. The PCM wil them control injection sequence and injector pulse width by turning on and off voltage to each injector, thru its ground circuit.
The PCM monitors the O2 sensorsinput and adjusts air fuel ratio by injector pulse width. It also adjs eng idle speed thru the idle air control (IAC motor).
The PCM also adjs ignition timing by inc or dec spark advance.
Well I would rater place a couple sensors that are at 118,000 miles then adjust the idle screw...at least yet. I do know that should all be controlled with the computer that rec. the data from the sensors...so if there is a bad sensor it is sending faulty data to the computer which in turn is not letting it adle correctly. I already bought the TPS sensor so I will replace it then I will take it to a stealership so they can charge me $50 to put there comptuer on it.
Thanks
rollerbones is offline
Just bought 03 Grand Cherokee, need help alauf05 ZJ Grand Cherokee Forum 2 08-24-2008 06:07 PM
just bought 06 grand cherokee LiLoleGC WK Grand Cherokee & XK Commander Forum 4 05-06-2008 08:51 AM
Just bought a 5.9 Grand Cherokee.... Tim062 ZJ Grand Cherokee Forum 19 08-28-2006 10:55 PM
Just bought my first Grand Cherokee DrEvil11417 ZJ Grand Cherokee Forum 6 05-09-2005 06:43 AM
Just bought a 97 grand cherokee... ou2mame ZJ Grand Cherokee Forum 1 03-31-2004 06:15 AM
