The bottom part of the PCV fell into the valve cover... - JeepForum.com
post #1 of 11 Old 04-06-2013, 12:33 PM Thread Starter
StPaul59
I was removing the PCV when it kept breaking apart and eventually the round bottom portion of the valve fell into the engine. Is there anything keeping it from falling farther. Do I have to take off the valve cover now and fish it out? Any opinions anybody? This has NOT been my day!
StPaul59 is offline
post #2 of 11 Old 04-06-2013, 01:35 PM
PolkaPower
Looks like you will be removing the valve cover. May as well replace the gasket.
PolkaPower is online now
post #3 of 11 Old 04-06-2013, 03:14 PM Thread Starter
StPaul59
Any tips on getting the valve cover off?? It wont clear the AC line.
StPaul59 is offline
post #4 of 11 Old 04-06-2013, 03:38 PM
PolkaPower
I found a leak in my ac line when I did my plenum gasket so I unhooked it then. I did the valve covers later but I had the ac lines unhooked by that point. I'm unsure if you can wiggle it out without taking it apart. If anything I would unbolt the compressor with the ac lines intact and see if you can gently shift it out of the way without bending anything too much but that is just a guess. I would google search "ZJ valve cover removal jeep forum".
In fact here is a thread. Yardman Harry did what I was thinking. You just have to be careful because bending the hose can cause a leak where they are crimped. http://www.jeepforum.com/forum/f13/r...askets-806604/
post #5 of 11 Old 04-06-2013, 04:03 PM Thread Starter
StPaul59
The compressor is loose. Only the AC line is stopping me. In that link it looks like there is something that would catch the broken PCV part to keep it from doing any damage... But Im already this far. Maybe a real hard tug would get this thing off. What a PITA!
StPaul59 is offline
post #6 of 11 Old 04-06-2013, 06:13 PM
PolkaPower
There is a bulkhead right under the top of the valve cover but I wouldn't take a chance leaving pieces in there.
post #7 of 11 Old 04-06-2013, 06:21 PM
xrunndonex
1994 ZJ
lift the driver hard side up push that way to then it'll clear the radiator hose. Then lift up on the front. disconnect the accelerator cable from the back of the engine bay and push it behind the valve cover. Then it's lifting and wiggling. Id suggest the felpro gasket it's 30$ but reusable and has torque stops. very worth it. Whatever you do don't get cork.
xrunndonex is offline
post #8 of 11 Old 04-06-2013, 06:23 PM
xrunndonex
1994 ZJ
and it didn't fall into the valves there's a filter like thing inside blocking it. don't put the pcv,boot on till after the covers back on. It'll just get in the way.
post #9 of 11 Old 04-06-2013, 07:04 PM Thread Starter
StPaul59
I got it off! I cant get that piece out of there at all. I dont think there is any chance of it coming out of there. The parts store by me has the felpro gaskets as well.
Some dirt fell in the valve area, Ill try to get as much out as possible but would the oil filter protect me as far as that goes?
StPaul59 is offline
post #10 of 11 Old 04-06-2013, 08:10 PM
xrunndonex
1994 ZJ
Yea it should mostly just oily dirt you should be fine as long as it wasn't metal. are you talking about the grommet or that stem? I,just replaced my stem couldn't get the grommet out but it still almost eliminated my rough idle. Id but the gasket on the block then put the cover on. Saves you from scratching the **** out of it when dealing with putting the cover back on.
post #11 of 11 Old 04-06-2013, 09:25 PM Thread Starter
StPaul59
Yeah just oily dirt and sand. I vaccumed it out but some might have fallen down inside there as I pulled off the valve cover. Next time I will clean that before I do the job. Grommet? You mean PCV valve? I tried to get the new one on there but it was a little too big. Might have to go the dealer route for that.
StPaul59 is offline
