Boost Help and Ideas :D spacers? - Page 2 - JeepForum.com
post #16 of 19 Old 06-09-2011, 10:35 AM
sskilla
Originally Posted by RussMan View Post
Okay, could I get the same basic 3.5" inch Kit or should I pay a little extra and get this one? Also can I put 3/4" spacers on all 4 shocks too? And if so will I need to do anything extra like extend brake lines? Links Are Below for everything. Thanks
If you can afford it, get that kit. cause its awsome and like ^^ said you wont need extended brake lines if you dont disconnect your end links. You may want to get the rear track bar drop bracket from IRO. its only 25 bucks or something. You will have a noticably shifted axle in the rear at 4.25"'s.
Originally Posted by russman View Post
Also here is a pic of my car as of now.
jeep, homie... jeep. you will learn young padawan... you will learn
'95 ZJ: 5.2 v8 / 231 Tcase / 46RH
sskilla is offline
post #17 of 19 Old 06-10-2011, 02:57 PM Thread Starter
RussMan
So if I buy the rear track bar drop bracket from IRO I can lift it to 4.25" with out needing any thing else that is not already in that kit? Thanks Guys
1997 Grand Cherokee Laredo I6, Running Strong at 176k! 2.35" lift running 31" Micky T's and a KOR rear bumper tire carrier.
"Dream as if you'll live forever, live as if you'll die today."
RussMan is offline
post #18 of 19 Old 06-10-2011, 11:35 PM
sskilla
just be aware that at 4.25"'s its going to be a rougher ride on stock control arms. the angles are pretty steep. as long as you can accept that you will be good until you get some cash and the "bug" to keep pouring into it lol.
also, your stock CA bushings are probably shot, so save up for new ones or plan on picking up some new CA's (can we say adjustables? ) in the future.
sskilla is offline
post #19 of 19 Old 06-11-2011, 01:45 AM
WhiteOut
WhiteOut's Avatar
You need to do a lot more research, figure out exactly what size tire you want and what you will use the Jeep for and how much you have to spend. In the space of two days you went from doing a 2" BB to doing a 4.25" lift bare bones. The bushings in your control arms are most likely shot, or just about there. Lifting it will destroy them for sure and it will ride worse than a piece of heavy equipment.
If you are just looking for a beefier DD (nothing wrong with this) then you can do a 2" BB, get a good set of shocks and some longer endlinks for the swaybar.
If you go 3"+ you need a front and rear trackbar, drop brackets do not cut it. Long swaybar end links for the front and back, shocks for that height and control arms. Going over 3" on a budget will only leave you hating the vehicle.
WhiteOut is offline
lift + spacers , lift advice , lift choices , lift help , spacers
Budget Boost johnny31d ZJ Grand Cherokee Forum 1 10-15-2010 10:25 PM
Budget Boost Plan-B ZJ Grand Cherokee Forum 13 12-17-2008 11:48 PM
budget boost q's steve L. ZJ Grand Cherokee Forum 6 12-02-2008 10:46 AM
budget boost goldj ZJ Grand Cherokee Forum 8 11-03-2007 08:53 AM
Budget Boost staggwj ZJ Grand Cherokee Forum 4 09-19-2007 08:00 PM
