Boingggg!!! in front end - JeepForum.com
post #1 of 4 Old 11-21-2003, 08:23 PM Thread Starter
Choff
Hi, all
I'm new to this forum (this is my first post) so here goes.
I have a '93 JGC with about 116k on it. When I had an inspection done on it a few months ago, they told me the ball joints were worn. I had it aligned then (which lasted about 2 weeks).
Recently, when making a fast left turn (either fast in speed, or hammering the throttle) it has started going BOING from the right front wheel area.
Could this be related to the "worn ball joints?" If so, how difficult are they to replace? I was quoted 600 bucks from the shop I was at, which seemed totally outrageous.
Thanks!
Chris Hoff
Choff is offline
post #2 of 4 Old 11-22-2003, 08:40 AM Thread Starter
Choff
Bumping it up ^ and adding more to be 20 characters
Choff is offline
post #3 of 4 Old 11-26-2003, 03:40 PM
jeepme79
If you had bad ball joints, there is no way the shop could have aligned it. Get your money back for the alignment, or fix the ball joints and have them re-do it.
2003 Dodge CTD Quad Cab 4x4, 320k miles and counting
Former Jeeps:
98 ZJ Limited, 5.2L, NP242, Jet Stage II (worthless), K&N, 245/75-16 BFG KO's
89 XJ, stock
79 CJ7 - Options included ripped soft top, leaky 4.2L (5qts/week), ripped seats, 33" tires, bondo & gray primer
jeepme79 is offline
post #4 of 4 Old 11-28-2003, 08:12 AM
Swamp Boy
Swamp Boy's Avatar
Ball Joints are not that hard.. Check your manual for directions and decide if you can do it or not..
If you decide to do it .. Go to Auto zone or something and buy a pickle fork and a 5 lb maul .. that will make it much easier..
I personally would not pay anyone that much money to do it..
It wont take you long to do your self..
Good luck...
Just another soccer moms Grocery getter....
Swamp Boy is offline
Front to Rear swap...can't I just steal front springs? allenjp ZJ Grand Cherokee Forum 12 02-08-2009 04:54 PM
front noise after removing front skid plate davets ZJ Grand Cherokee Forum 2 12-08-2008 05:54 AM
Front driveshaft too long after swapping front differential jjeeeeppss ZJ Grand Cherokee Forum 11 08-12-2008 05:19 PM
Vibration in Front End Possibly Front drive shaft??? CrazyDrivinJoe ZJ Grand Cherokee Forum 4 11-21-2007 04:56 PM
Replaced front axle/CV joint now a bad whining from front end? f1rz06 ZJ Grand Cherokee Forum 4 09-16-2004 02:48 AM
