Bogging down/low rps in reverse - JeepForum.com
post #1 of 10 Old 01-14-2014, 05:02 PM Thread Starter
zjforlife
First issue I've been having with my ZJ is about 4-5 months ago I welded a glasspack on my exhaust and ever since then it's been bogging down really bad when I giving it full throttle and quickly release the gas it goes from about 2200 rpm to 800 quickly fluttering and barley staying high enough not to die Bad cat? Idk any help would be appreciated
The second issue I'm having is when I put her in reverse idles at 500 rpm almost completely fluttering out it also wobbles from the rear passenger side it stays just high enough in the rpms not to die thanks for any advice guys
zjforlife is offline
post #2 of 10 Old 01-14-2014, 05:16 PM
dusterdude
Some mufflers are directional,check yours and see if it is installed correctly
dusterdude is offline
post #3 of 10 Old 01-14-2014, 05:20 PM Thread Starter
zjforlife
This glasspack was a straight tube it didn't have any arrows on it or inflow outflow sides good advice tho any other ideas?
post #4 of 10 Old 01-14-2014, 06:52 PM
JasonStebbins
Sounds like a back pressure issue regarding the exhaust. Could be a clogged converter.
Have you checked the transmission fluid level while running warm in neutral?
Poop
JasonStebbins is offline
post #5 of 10 Old 01-14-2014, 07:05 PM Thread Starter
zjforlife
If the cat is blocked could would it be easier and more cost efficient jus to replace and I dropped the pan a few months back and the fluid all still pink for the most part
post #6 of 10 Old 01-14-2014, 07:42 PM
JasonStebbins
If it is the converter, they aren't that expensive. Might as well get a high-flow model if you go that route. Is yours original? Could be something else causing the issue, but it sounds like a back pressure/exhaust problem if you let off and it almost stalls out.
Have you checked the dipstick level though? Mine was doing something similar when I had a pin hole leak and the fluid got a little too low.
Poop
post #7 of 10 Old 01-14-2014, 07:53 PM Thread Starter
zjforlife
I'll check again tomorrow all of the fluids and I hope it's just the cat could it possibly be a air filter?
post #8 of 10 Old 01-14-2014, 08:05 PM
JasonStebbins
Highly doubtful unless it's the original from 1998.
I'm not positive it's the converter, that's just my suggestion from your symptoms. Does it drive fine the rest of the time? What happens when you floor it from a dead stop, any restrictions or bogging down? Experiencing any other problems besides when you let off the gas?
Poop
post #9 of 10 Old 01-14-2014, 08:13 PM Thread Starter
zjforlife
When I floor it just spins the wheels and doesn't shift until about 2200 but I thought that would be a Trans problem and it the original haha
post #10 of 10 Old 01-14-2014, 10:27 PM Thread Starter
zjforlife
When I drove home tonight from work the ZJ did ok no bogging down but I believe this is because of the low temp after a few runs the ZJ did it again I think temp might be affecting the bogging down ideas?!
